Autotrail Tribute grey water tank
Houghta
Houghta Forum Participant Posts: 45 Participant
edited February 2019 in Motorhomes #1
has anyone come up with a sollution to allow the grey water to be syphoned into a waste master or similar on an autotrail tribute with the underlung grey water tank and a drain hole approx ø60, we are going to be on site for around 8 or 9 days with an awning attached so want to be able to drain off some of the grey water periodically without having to slide a plastic bowl underneath everytime, hoping someone may have come up with some form of hose or pipe connection
thanks,
    edited February 2019 #2
    Tinwheeler Forum Participant Trusted Posts: 24,255
    edited February 2019 #3
    You should be able to buy the correct diameter hose and a connecting elbow joint in a cvan/MH accessory shop. You’re unlikely to find the right size in a domestic DIY outlet. Many of us carry such a set up for the odd occasion we can’t use a drive over drain.
    Edit: we posted together, BB.
    edited February 2019 #4
  • Houghta
    edited February 2019 #5
    It’s a 670 a van conversion
