Leisure battery changing
MIKWOO
MIKWOO Club Member Posts: 5
edited January 2019 in Parts & Accessories #1
Hi folks. I am looking for some advice regarding a battery charger. I have a bulk standard 6amp charger in the garage. My local agent tells me this is not suitable for charging a leisure battery. Having searched on line I thought I had found a good deal for a smart battery charger at my local Europarts depot. The very helpful fellow behind the counter advised me that what I already have is suitable for my needs. Does anyone out there know enough to advise me what I actually need. F.y.i. battery became flat over new year due to a faulty water pump connection. This has now been addressed. Cheers.
  • Milothedog
    edited January 2019 #2
    Any modern conditioning / maintenance charger will do the job.  Just make sure it's designed to work with what type of battery you have, (i.e. AGM, Lead Acid etc) and suited to the batteries AH.
    Google  ctek  or optimate, both are good makes. Cheaper ones are available but you get what you pay for like everything in life.
  •  viatorem
    edited January 2019 #3
    The different advice regarding the agent and the europarts depot could arise from where you intend to charge the battery.
    On a workbench in a well ventilated area any suitable charger would do. Within the confines of a leisure vehicle battery box the charger should be limited to reduce gassing as there is an explosive risk.
    edited January 2019 #4
  •  viatorem
    edited January 2019 #5
    I have the ctek charger mentioned above which is great for conditioning and maintenance of batteries on the bench.
    I also have one of these which does a similar job but is much more versatile being able to boost charge your starter batteries wth 60A. It has never failed to start my car or numerous neighbours when needed.
    https://www.blackanddecker.co.uk/en-gb/products/car-care/battery-chargers-new/20a-battery-charger-with-engine-start/bdsbc20a
    Both of these should be used with the battery in a ventilated area.
  • lester1971
    lester1971 Forum Participant Posts: 1 Participant
    edited February 2019 #6
    ive just bought the ctek mxs-5.0 and its brilliant for trickle charging , desulphation and reconditioning your leisure battery, its does all types of batteries from wet, amg to gel ones at about £65 for charger its decent for the price
