Front running lights
Graymee
Graymee Forum Participant Posts: 84 Participant
edited November 2018 in Caravans #1
My Bailey Pageant Provence has white running lights roughly level with the bottom of the front windows. If I'm towing on a wet night these sometimes make it quite difficult to see what's behind me if there is spray on the mirrors. Is it a legal requirement to have working running light or could I remove the bulbs. They're only 5W bulbs so I doubt I could get lower wattage bulbs so they're not so bright.
  • DaveCyn
    DaveCyn Club Member Posts: 410
    edited November 2018 #2
    Simple answer they are a legal requirement.
    Maybe try different mirrors.
  • Graymee
    edited November 2018 #3
    Do you have a reference? Where is it laid down that you need them? I'd like to read the reference to see if I could disable them and put other lights higher up if that's possible.
  • DaveCyn
    edited November 2018 #4
    The reference is the Road Traffic Act 1988 which requires all vehicles, including trailers to show white lights at the front when on the highway.
    It's a very lengthy document which the Highway Code is based on.
  • Graymee
    edited November 2018 #5
    I'm more inclined to think the facts would be in the Road Vehicle Lighting Regulations not the Road Traffic Act.
  • DaveCyn
    edited November 2018 #6
    The RTA covers everything that moves on the highway, all other's are derived from its content.
    edited November 2018 #7
    could you not disable them and place new ones lower on the front skirt. That's where most caravan front running lights are and I don't think there is a law that says they have to be a certain height above ground level.
  • Vulcan
    Vulcan Club Member Posts: 676
    edited November 2018 #8
    If that is the case why have you asked the question when it is clearly stated in the Road Vehicle Lighting Regulations 1989.
  • Lutz
    Lutz Forum Participant Posts: 1,695 Participant
    edited November 2018 #9
    What you could perhaps do is to move them further down. The regulations only state that the lights must be no more than 1500mm above the ground.
    edited November 2018 #10
    I'm sure that the front lights on my 2007 Abbey were higher than that. BICBW
    edited November 2018 #11
    similar to what I suggested Lutz.
    edited November 2018 #12
    Do you not find that your front towing cover sometimes "accidentally" covers the trailer lights?
  • richardandros
    richardandros Club Member Posts: 3,231
    edited November 2018 #13
    Both towing covers I have had, have either battery operated lights in pockets on the cover or purpose made plastic panels for the lights to shine through.
