Fresh Water filling
johnthomo
johnthomo Forum Participant Posts: 23 Participant
edited October 2018 in Motorhomes #1
Second appeal for advice today. You can tell I'm new. We've just had a few single nights away in our new Motorhome and 3 of the 4 sites we've visited have had hard standing with both electric and water. However, this weekend the water was some considerable distance away. I decided not to fill up at home before leaving and we were very low on water, hoping to top up on site. Fortunately, we left before the lack of water became a problem. Would I have to move my Motorhome to the water or is there another solution? Fill a container and pump it in maybe?
«1
    edited October 2018 #2
    Tinwheeler Forum Participant Trusted Posts: 24,401
    edited October 2018 #3
    You can use a container and pump, a watering can, of anything you fancy. It’s much easier though, in my opinion, to fill at the dedicated MH service point (if there is one) on arrival at the site.
    When touring, we fill and empty either on arrival or as we leave. Only once have we needed to fill via a pump and bucket.
  • ABM
    edited October 2018 #4
    I  always  carry  a  2 to 3 metre  length  of  clear  hose  with  a  'Hozelok' tap  connector   to  allow  me  to  fill  up  if / when  passing  the  water  points.  Otherwise,  like  HuskyPup,  I  carry  a  red  10  or  so  litre  watering  can.  First  started  carrying  the  'can  on  Orkney  back  in  the  '80s  when  the  hose  was much  to  short  to  reach  the  taps.
  • mickysf
    edited October 2018 #5
    Personally, when on the road, I would only ever carry enough water on board for a cup of tea or two. Always fill up on arrival with either that blue potable plastic hose or our plastic 15L water container. Have a plastic elbow which fits the filler opening on the exterior of the van, this helps greatly and reduces 'wet leg'!wink
    edited October 2018 #6
  • BrianJosie
    BrianJosie Forum Participant Posts: 391 Participant
    edited October 2018 #7
    We always fill up before we leave home and 200ltrs lasts us 4/5 days laughing
    If we need to refill we have 2 x 40mtrs of hose on board or if we need to we have an aqua roll and a 12v pump.
    so in answer to your question ,no we neve.r need to move the Motorhome to fill up with water.
    Brian & Jo
    edited October 2018 #8
    Many people carry a flat food grade hose of around 6 meters and a small selection of hozelock fittings - generally a threaded attachment and a push-to-fit adaptor are all that are required. The flat hose is very compact.
    Assuming you were given a submersible pump you can fill a container and use the pump, alternatively carry a 5-10 litre watering can and make a few trips back and forth.
  • Aspenshaw
    edited October 2018 #9
    Only two johnthomo? You're already halfway to being an expert!
    The answer is you don't have to go to the motorhome service point. There are many options and it is best you choose one that suits you n the motorhome.
    I tend to travel with 25l or so. I top up on site using a food grade watering can from
    FloproGarden-Sprayers
    The only downside is that you may have to get stick some plastic tubing on the spout because the spout may not be long enough. Oh and as it only holds 8 litres, several trips are necessary.
    I've also used food grade containers [with a tap] and poured the water directly into the tank after removing the big water tank cap. Sometimes I get water splash on the van floor doing this. A plastic pop bottle can be cut to form a funnel so I can stand outside, pour from the container, down the funnel and into the tank.
    I carry a short length of food grade hose - c 8m long - with a connector so I can fix it to the longer hose. As we travel with water, it's easy to top up using this short hose when returning to the pitch after a day out.
    You don't need to use food grade.That's a personal decision. I've not known anyone to die from using an ordinary hose.
  • mickysf
    edited October 2018 #10
    I recall some years ago that a celebrity, can't remember who, filled his water tanks up with deisel. What a mess that must have caused.
  • KeithandMargaret
    edited October 2018 #11
    We fill up our fresh water tank before leaving home, three days later we top it up, three days later we top it up, ad infinitum …....
    I have a clear plastic pipe around three metres long and have never used anything but that in over six years in this country or abroad.
    A Motorhome water filler cap helps to take any strain of filling away completely as the water flows in for around ten minutes.
    I don't have a watering can, bucket or aqua-roll and try to keep things, like me, simple.
    edited October 2018 #12
    I believe that is not uncommon. There is a “sticky” on the Autosleepers forum about what to do in that situation.
  • S6 Kevin
    S6 Kevin Forum Participant Posts: 35 Participant
    edited November 2018 #13
    We always travel with empty tanks and fill up at the service point on arrival. We have a selection of Hozelock fittings on food grade hose. We also have a HEO Solutions water connector, this is put in place of the water filler cap on the motorhome, it has a hozelock male fitting and makes it an easy one man job with no 'splash backs'
    We carry a couple of containers should we need to fill/empty whilst on site. A small fold down trolley is very useful. An external submersible pump is also an asset
    edited November 2018 #14
  • QFour
    edited November 2018 #15
    Couple of watering cans is all you need. Ours is 120 Litre tank so take six trips to fill. Its far easier to carry two cans than one and you cut down the walking distance.
    Watering cans unlike hosepipes FIT all taps
    edited November 2018 #16
    peedee Forum Participant Trusted Posts: 10,163
    edited November 2018 #17
    Agree two watering cans are easier to carry if you have the space to store them. Why make two trips to a tap when you can do one. I also carry two hoses, a short 10m one and a longer stretchy one. They can be joined together if necessary and with the tap adapters I hope I have everything covered. I usually travel with some water and fill up on arrival. Not had a problem yet.
    I also carry two 10L collapsible buckets, got them for £3.99 each from Home Bargain Stores
    edited November 2018 #18
    One of the reasons for us swapping to a MH was to do away with the need to fetch and carry water and waste. No way do we fill or empty the tanks with buckets/cans unless it’s a dire emergency. What could be simpler than driving to the tap and drain?
    edited November 2018 #19
    edited November 2018 #20
    You often have no choice on a CL. or other sites with inadequate dump areas. One reason why I think the Club should open its sites to members to come off road and use site MSVPs albeit for a fee.
    edited November 2018 #21
    There’s always a drain of some sort, PD, which can usually be reached with a hose if necessary.
    edited November 2018 #22
    I'd sooner pay to use a proper disposal and refill point than risk poluting water courses into which many roadside drains empty.
    edited November 2018 #23
    Who's talking about road drains? That’s not something I’d contemplate.
    CLs and others sites, as we were talking about, always have a waste water disposal point of some sort which can usually be reached with a hose.
    edited November 2018 #24
    edited November 2018 #25
    Us, too, but the hedge is the "waste water disposal point of some sort" on those sites and can be accessed with a hose with no need to carry the waste water.
    edited November 2018 #26
    Various CLs have told us specifically to use hedge rows to dispose of grey waste ..... it's only soapy water.
    edited November 2018 #27
    Exactly. As I said, it is the drain of some sort.
    edited November 2018 #28
    So you do not have other than soapy? water  to dispose of?no grease or bits of food waste, washing up liquid is not soap as  most showering liquidssurprised
  • Takethedogalong
    Takethedogalong Forum Participant Trusted Posts: 18,482
    edited November 2018 #29
    We only have soapy water in our grey tank. We use a wash up bowl for pots and draining veg, that just goes to on-site grey waste. Easier to keep grey tank clean this way, rather than having any food bits in it.
    We fill up/empty as we go out/ come in for day in MH. What could be simpler? We don’t carry fancy pumps, aquarolls, wastemaster etc... just a hosepipe, selection of fittings, and a collapsible bucket and / or a bit of pipe.
  • dmcv
    dmcv Forum Participant Posts: 14 Participant
    edited November 2018 #30
    Fill up at MH point as you arrive. Carry a watering can to top up if you are staying for more than a few days. We only drink water from a bottle (not bottled water which we fill from the drinking water tap.  We dont like drinking water from the mhome tank. Many people do though. Its a personal choice.
    edited November 2018 #31
