Hot water problems with shower
Ellie521
Ellie521 Forum Participant Posts: 2 Participant
edited October 2018 in Motorhomes #1
Back in September we traded our caravan in for an Elddis Impressa 175 motorhome. Right from the start we have had problems with the hot water in the shower. My routine for a shower is to wet my hair, turn off tap, soap hair, turn tap back on and rinse hair, turn off tap, apply conditioner and then soap body whilst tap is off. Then finally turn tap back on and rinse hair and body. This is the way we showered in our caravan and we managed to get two showers and some washing up done with one tank of hot water.
Sadly in the motorhome, by the time I turn the tap on to rinse my hair after shampooing, the water is already getting cooler. I am normally only a quarter of the way through rinsing my body before the water is absolutely freezing. I estimate this to be between two and three minutes of warm water if that.
We took the motorhome back to the dealer and they told us it was because it had a smaller tank than the caravan (8 litres rather than 10 litres). Surely it shouldn’t make this much difference?
We are planning to go touring for a year in our motorhome in the future but how can we do this if we cannot have a semi decent shower especially in the winter. We are beginning to wish we’d kept the caravan!
Has anyone else had this problem with their hot water?
    edited October 2018 #2
    Not had the problem but have used both gas and electric tank heaters on at same time to prolong the availability of hot water.
    A suggestion in a similar thread a while ago was to reduce the flow rate so there was less water coming out. Some showers have a washer in the flow line that can be changed to one with a smaller hole.
    edited October 2018 #3
    Maybe a different shower head?
  • KeithandMargaret
    edited October 2018 #4
    Are you heating the water by gas or electric ?
    We found we have more hot water (for longer) when we use gas.
    No idea why - but we do.
    This is in a Pilote MH.
    edited October 2018 #5
    Are you using the 2kw setting for the water heating element and is the water temp set to 60°, or more if possible? If not, there is unlikely to be enough hot water to do very much.
    The hotter the water to start with, the more cold is mixed from the tank to set a usable temperature. Thus the hot water will last longer.
    As hot water is used, cold water enters the water heater and starts to cool the contents.
    edited October 2018 #6
  • brue
    edited October 2018 #7
    We've found that if one of us has a wash first it tends to lessen the amount of hot water, so spread the usage out if possible and get an eco camel shower head, we've got one and it does help reduce the volume going through.
    edited October 2018 #8
  • Tammygirl
    edited October 2018 #9
    No issues here with that BB, we only have a 23 Ltr water container but we can both have lovely hot showers one after the other in the new caravan (also in the previous mh)
    I go first (of course) the OH follows me. We have the hot water on high heat, we've only used it on hook up so far but no problem with running out of hot water.
    The shower head is a camel one and the pressure is the best we've ever had and can put some of the club sites to shame.
  • MichaelT
    edited October 2018 #10
    We find you need to have the water on boost and wait till the thermometer on the control panel stops flashing (meaning the water has boosted to required temperature) then you can use it, so long as Mrs T does not wash hair and we are having a quick shower we can get 2 out of a full tank albeit it is getting cooler at the end of the 2nd shower.  Best to wait another 10 mins or so for the water to reheat.
    We do find if you use Mix 2 it does heat faster (obvs) and seems to get hotter.  We have Truma 6e Combi boiler.
  • Ellie521
    edited October 2018 #11
    Hi, thanks for all your responses. We have tried the shower using gas but it doesn’t make any difference.
    We will try a new shower head and also checking the temperature and filling a bucket. I don’t think the temperature is a problem as it’s always scorching when we first turn the water on, it just seems to start cooling down very quickly and then go freezing.
    We are due to go away end of November so will try the suggestions.
  • Vanbirds68
    Vanbirds68 Forum Participant Posts: 149 Participant
    edited October 2018 #12
    Yes we find this. Mr VB says the electric heating element is placed higher in the tank than the gas one, which is at the bottom of the tank. As someone else has said - you can run both together to ensure you have plenty of hot water. Sounds like a miserable experience you’ve got now, hope you can get it sorted.
    edited October 2018 #13
    edited October 2018 #14
    We find our truma if needing more hot water just put the boost on
    edited October 2018 #15
    The water will heat quicker on gas than electric. The cold water going into the tank will, therefore, not have such a dramatic cooling effect because it’s heating quicker.
  • Takethedogalong
    Takethedogalong Forum Participant Trusted Posts: 18,300
    edited October 2018 #16
    I seldom wash my long hair in the van/MH, purely and simply because I use too much water trying to get all the conditioner out. Prefer to have a decent shower using onsite facilities. Two showers with hair wash/condition was fine when I had short hair. You also need a decent pressure to rinse conditioner out. I have debated having hair cut a few times.......
    edited October 2018 #17
    edited October 2018 #18
    We have an Alde system which I think is a 8 litre hot water tank. We only use it on Electric and normally only on a service pitch. I like a reasonable shower, so allow the tank to heat up again (30 mins) after the OH has showered. There is a noticeable difference in the length of shower if boost 70C is used, rather than the standard 60C . There is also a noticeable difference between length of showers winter and summer. Presumably because the replacement water is that much colder in winter. Although I assume that wouldn't be as marked with a MH's inboard tanks.
    However, summer or winter, on either setting, there is ample for a good long shower. Sufficient to wash hair and body without turning off. Although I do because, of the showers small size, the soap would wash off before applied.😂 We have an eco camel shower head, which I think makes the available water stretch significantly further.
