Truma Ultraflow water inlet hose
BikingBob
BikingBob Club Member Posts: 18
edited August 2018 in Parts & Accessories #1
I have recently had to replace the above for my van but am finding the hose is tending to curl whilst in the aquaroll and thereby allowing air to be drawn in as the water level reduces. Has anyone experienced this and/or any suggestions for solving, please?
One thought is to weight the filter but what to use?
Many thanks.
  • ask66
    ask66 Forum Participant Posts: 43 Participant
    edited January 2019 #2
    Hi BikingBob,
    Did you ever find a solution to the problem?  I've only just seen your post but maybe five months late is better than no reply at all?!
    My solution was to run the inlet hose through a piece of rigid plastic pipe within the Aquaroll itself - I used some surplus 3/4 inch overflow pipe.  I ran the pipe vertically from the inlet to the bottom of the Aquaroll.  In fact this still allows it to lift a little (diagonally).  If I did it again I'd use a longer piece of rigid pipe, run diagonally to the bottom of the Aquaroll - this would leave no room at all for it to lift.
    Would be interesting to know what others have done!
  • richardandros
    richardandros Club Member Posts: 3,218
    edited January 2019 #3
    I noticed this problem on our new Knaus Starclass which was fitted with the Truma Ultraflow system.  It was a pain, not only for the reasons mentioned in the OP, but also you have to remove the pump/hose completely every time you fill the Aquaroll because there's nowhere to clip the pump / hose as on the Whale system.  Added to which the water flow from the Truma pump is much less than the Whale High Flow.
    The solution was quite simple - I bought the Whale High Flow pump with the Truma connection which is a one for one replacement and sold by most caravan dealers.  Pipe is more flexible, water flow vastly improved and there is a clip on the top to take the hose whilst filling the Aquaroll.
