Electric problems
Mistrom
Mistrom Club Member Posts: 20
edited July 2018 in Caravans #1
Hello all,
I am currently having a problem with my caravan electrics when towing.
When I hitch up ready to tow and turn on the unit to charge the leisure battery and run the fridge, my near side indicator remains permanently on. A message appears on my car dashboard indicating ‘ trailer signal bulb failure ‘ . The fridge is on and in battery mode and all else inside appears ok.
However when I turn the power off inside the caravan and just run with the lights the indicator works normally.
I assuming there is a bad connection somewhere.
has anyone ever had a similar problem?
Could it be the fuse?
The bulb itself?
Any help would be greatly appreciated.
Many thanks in anticipation.
    edited July 2018 #2
    Is it a problem that has just shown up in an outfit that has previously been OK?
    What model and age of car.caravan?
  • moulesy
    moulesy Forum Participant Trusted Posts: 9,419
    edited July 2018 #3
    What sort of connection do you have? We had a similar problem using a 13 to 2x7 pin adaptor which turned out to be something shorting in the adaptor itself.
  • Mistrom
    edited July 2018 #4
    Thanks for the quick response,
    The caravan is a Sprite Finesse 2010
    13 Pin adapter.
    All has been ok previously
    edited July 2018 #5
  • ForestR
    edited July 2018 #6
    Similar problem in 2014. Found water in adapter had caused serious corrosion and poor earth. Became more costly when visit to nearest dealer to buy a new adapter lead to purchase of new caravan!
    edited July 2018 #7
    Certainly likely. Water in car socket also
  • alfigone
    alfigone Forum Participant Posts: 48 Participant
    edited August 2018 #8
    Something else I'd check would be the how secure the pins in your 13pin plug are. The feeds you mention are on pins 1, 9 & 10. They are all close to each other.
    I recently had an issue with my offside indicator & sidelights coming on together on the van, and eventually traced it to pin 5 being loose. When I inserted the plug, pin 5 was pushed back in the plug & shorted against pin 4, however when the plug was removed the pin was held by the socket & pulled back out so on a visual inspection all appeared OK.  It was only when I put meter across the pins looking for the short, that I found it, as pin 4 pushed back into the plug under pressure!
    New 13 pin plug resolved the issue.
    edited August 2018 #9
    Never take the other half to a dealers for parts. while your sorting the problem there spending.
    edited August 2018 #10
  • ForestR
    edited August 2018 #11
    Your advice is sound and in fact OH stayed outside with dog while I bought new adapter but a very astute salesman invited OH and dog in.smile
    No regrets as got a great deal on new Coachman 4 years ago this week which at 4th service last week was damp free and without any major problem.
    edited August 2018 #12
    If I had a caravan that was 4 years old with no damp I would have kept it as that's seems a novelty these days.
  • Rufs
    Rufs Club Member Posts: 4,105
    edited August 2018 #13
    not if its a Coachman, I have one 8 years old and still sound, when not in use stick a Unibond Aero 360 in there, this will collect all the unwanted moisture, magic
