Fridge not cooling down in hot weather
legs down in WF15
legs down in WF15 Forum Participant Posts: 2 Participant
edited June 2018 in Parts & Accessories #1
Whilst in France last summer our fridge struggled to get down to a cool temperature when it was very hot outside.  Our Bailey dealer said we should use the gas to power the fridge to start with then turn it onto the mains electric.
Has anyone else suffered with this or has any recommendations for our trip this summer?
    edited June 2018 #2
    As a veteran of southern France when it can get up to 35 deg. plus we have certainly experienced similar problems withour Bailey and other vans.  There are basic limitations with absorption type fridges (rather than compressor type) but I must say that the Thetford on our newish motorhome works perfectly in temperatures in excess of mid-thirties so the latest designs have improved enormously.
    Fitting fridge fans helps a bit and that is something you can do yourself if you are practical.  There have been instructions on this forum and elsewhere - I used two computer fans salvaged from old computers.
    We have a fridge thermometer and used to find getting into the green area (about 10 deg. C I think) could be problematic. Gas is more efficient but you will get through a fair amount if you use permanently.
  • Swifty2018
    Swifty2018 Forum Participant Posts: 196 Participant
    edited June 2018 #3
    During the handover on our new van, the technician told us when the weather is hot and the fridge is struggling, the answer is to turn the fridge dial down. Whilst this seems counter intuitive he assured us it works!
  • GodivaNige
    GodivaNige Forum Participant Posts: 606 Participant
    edited June 2018 #4
    Wont make a blind bit of difference, it’s a thermostat and is either on or off.
    The thermostat will remain unsatsified until the box reaches a certain temperature when it will open and cut power to the heating element (or close the gas valve)
    Turning the thermostat to a lower temperature will not increase duty, all it will do is remain unsatisfied to a lower set point.
    Absorption refrigerators as opposed to Freon compressor systems, use ammonia solution which isn’t particularly efficient when the temperature differential is reduced across the condenser as seen with hot ambient temperatures. Fans across the condenser help shift heat and allow that differential to open and create better conditions for the gas to exchange heat.
    edited June 2018 #5
    fridges should run about 4-5 deg's. stops bacteria build up, unless only used as a drinks fridge and not a salad one.
  • Snooky
    Snooky Club Member Posts: 78
    edited June 2018 #6
    Hi
    we have a Bailey caravan and experienced the same situation with our fridge, On advice of both dealer and Bailey, when it’s hot: we start the fridge on gas and then turn over to electric once cool.  To test put a cup of water in freezer and when frozen you’re good to go electric
  • GodivaNige
    edited June 2018 #7
    Yes, there is more power in the gas flame than the mains heating element, just as there is greater power when on mains compared to 12V
    Be aware though that absorption fridges are designed to maintain temperature and are not blast chillers. Where possible, always run them with a full box of already chilled/frozen items. Don’t expect them to pull ambient products down terribly well, they are not designed for that.
  • GodivaNige
    edited June 2018 #8
    1-5C is the ‘official’ cold chain limits for dairy & meat
    below -18C for frozen and above 70C for hot served foods
  • jennyc
    edited June 2018 #9
    Our Dometic fridge has been troublesome from new. The manufacturers insist that it needs servicing annually. The tell us that it should achieve a 15 deg temp reduction from the outside temperature. Hmmm that’s down to 10 deg when the outside temp is 25deg. Advice to remove the fly screens from the vents and to fit auxillary fans has been fruitless. The dealer can’t find anything wrong. So at considerable expense we had a new refrigeration unit fitted (it comes as one piece). The current heatwave has been spent on our garden project, so it’s not been tried out yet. We never had these problems with Thetford units.
  • hastghyll
    hastghyll Forum Participant Posts: 42 Participant
    edited June 2018 #10
    I had my van serviced recently and the person doing the service told me he had been on a course at the Dometic factory. There he was told that on some models Bailey designers had ignored fitting instructions which meant the fridges would never work properly.
    The top vent outside the van should be level or above the top of the fridge or the air doesn't circulate properly. After fitting tall fridges they had only put them halfway up. On some vans they put the fridge on the nearside next to the van door. If you open the door and hook it back it partly covers the vents. Also if you have an awning the vents will be inside it.
    This is only what he told me but I have no reason to doubt it.
    edited June 2018 #11
    That makes sense. The heat comes directly out of the back of the fridge and the vents create a chimney effect with the hot air rising to the upper vent which needs to be nice and high. Fitting an extract fan at the top should help in that situation.
    Despite all the adverse (and justified) general statements about absorption fridges, I can only repeat my previous comment that Thetford seems to have solved it. Ours works fine in ambients of 35 degrees so it’s clearly possible. Maybe it’s a combination of Thetford plus how Autosleeper’s have fitted it.
    edited June 2018 #12
    edited June 2018 #13
    Our MH has a Dometic and, although not exceptionally warm, it is freezing OH's yoghourt in the middle of the fridge.
  • Woody19
    Woody19 Forum Participant Posts: 43 Participant
    edited July 2018 #14
    To explain about fridge fans....
    Get a couple of 4inch 12V computer fans and fit one inside the lower vent blowing in and one behind the upper vent blowing out. The direction of rotation and air flow are embossed in the outer frame of the fan. Wire the fans in series which will make them run slower and much quieter. A switch is a good idea as just making the air move rather than relying on convection will improve the efficiency of the fridge enormously - you don't want everything freezing up!
  • C9C9C9
    C9C9C9 Forum Participant Posts: 80 Participant
    edited July 2020 #15
    My two cents despite this being an old thread.  I have a Dometic RM8551 with poor performance.  I've just returned from Bernese Oberland at the beginning of July in Switzerland where temperatures in the shade didn't exceed 30 degrees C.  Further I had air con running in the caravan keeping the internal temperatures sub 25 deg C.
    Nonetheless, Ice lollies where melting in the freezer, so it could not maintain much <0 deg C.
    I have a dometic 12 V fan installed, and I was running on mains.  I did not try on gas, but on previous years, this didn't help much (why shouldn't I use mains, does mains not work by design?).  The performance was even more diabolical without the fan, it is now just diabolical.
    I installed a glorified commercial potentiometer across the thermistor (you can buy a commercial unit),  which didn't help, so removed it.  I'm considering installing a fridge from an alternative manufacturer, I'm fed up of warm beer and soggy frozen goods.  Furthermore, in my opinion its cooling capability is inadequate to the point that it could be dangerous.
    Incidentally today the fridge compartment is sitting at ~8 deg C in the centre of fridge - the freezer is at ~0 deg C, and it is 27 deg C outside.  Typically people aim for <4 deg C for a fridge, and -18 deg C for the freezer.  The internal caravan temperature is 25 deg C (air con is on), typically people would not have air con, and this should be making things easier for the fridge.  I'm underwhelmed by its performance.
    A lot of urban myths are going around about setting the the thermostat to a lower temperature (why, is it broken by design? does high not mean high?).  Moving the thermistor, left, right, up and down, or removing thermal compound from the fins (can't this be done correctly when manufactured).  I once owned a dometic RC1600, it was awesome in France, so in principal I know an adsorption fridge can work, just not this one.
    edited July 2020 #16
    If it is the tall domestic fridge it was in 2016 anyway a problem with some fau lty gas valves  that somehow made the fridge over cool when on mains  electric ours and two others were rectified by a mobile Dometic engineer when at Ferry Meadows
    I  do not know about smaller models
  • Bryn Whyte
    Bryn Whyte Forum Participant Posts: 8 Participant
    edited February 2021 #17
    It seems a common fault on Bailey caravans using Dometic fridges.... Ladt year with the awning on my fridge could not keep tempeture..I removed both exterior plastic grills, which dropped a couple of degrees I am in the process of having two fans installed to extract hot air and circulate fresh cool air...
  • commeyras
    edited February 2021 #18
    Browsing and just come across this thread.  I think that what the dealer said to the OP is basically right.  We have a Bailey but with a Thetford fridge.  Most of our caravanning is in hot climate areas and we rarely have problems with our fridge.  Too keep it cool when in temperatures of 40 deg I put a small fan on the outside blowing into the lower vent, this seems to work and is a simpler remedy than the technical one explained earlier.  If we load the fridge up after shopping with a lot of veg etc which would be at 'room' temperature then, yes, run it on gas to get it cool then switch to mains.
