Chausson flash, Ford chassis with engine problems
BrogM
BrogM Forum Participant Posts: 2 Participant
edited May 2018 in Motorhomes #1
Recently purchased a 15 plate Chausson Flash on a ford chassis and on first trip it flashed up a warning and it dropped into limp mode.
This has now happened a number of times ( with 3 garage visits) , I was wondering if anyone else has experienced similar problems..?
    edited May 2018 #2
    Were your garage visits to a Ford commercial workshop with the right diagnostic computer to analyse the fault codes?
    EGR valve is a common problem but others are available.
    Do you have a Ford warranty or a dealer warranty or buy privately?
  • BrogM
    edited May 2018 #3
    Hi, yes all were to ford dealers, but faults cleared, and nothing logged. Thought the computer would log faults, but no! Need to get to dealers without turning ignition off!!
    Bought from a dealer with a years warranty, love the vehicle, but not at all happy with problems, planning a long trip at end of year but feel I can't trust it.
    Just wondering if it's a problem with transits!
    edited May 2018 #4
    In your shoes I’d march it back to the dealer and don’t be fobbed off by him telling you to take it to a Ford garage. He sold it to you and it’s his responsibility to sort out problems. If you can’t get the van to the dealer, get him to collect it.
    I can’t imagine it being a common problem. White van man wouldn’t stand for it!
  • Randomcamper
    edited May 2018 #5
    If you type  "Ford Transit Limp Mode" into Google, loads of results come up.   I'd have a read through those & see if anything sounds like your van......
  • TonyIshUK
    TonyIshUK Forum Participant Posts: 295 Participant
    edited May 2018 #6
    Depending on how techie you are,  you can get a OBD code reader from Amazon for £30, read the codes and reset some of the advisory codes if need be.
    Fiats (I see yours is a Ford) can be plagued with earthing faults between the engine, gearbox and ECU.    My Fiat has a fault that pops up at irregular intervals for no apparent reason.  I reset the ECU reading, until next time, apparently different reason.
    rgds
  • Existedsteed
    Existedsteed Forum Participant Posts: 15 Participant
    edited December 2018 #7
    Hi brogm
    i see your post is from a while back - I've just experienced the same symptoms in my 2016/17 chausson Ford based m/home 5500 miles only.
    , 50 miles after its 1st major service. Ford Assist attended after I "limped" back home and diagnostics revealed injector No1  failure/issue. I'm booked to be recovered to Ford dealer tomorrow morning. Can I ask what your outcome was?
    edited December 2018 #8
     You can ask but are unlikely to get a reply as the OP has only ever made two posts and those are the two on this thread
  • ATDel
    ATDel Club Member Posts: 335
    edited December 2018 #9
    There is a lot of information on line re ford transit 2.2 injectors, if I remember rightly ford tried to get away with changing only one injector and some had other injectors go. All injectors need replacing. To be forewarned do some homework and go armed with information
    have a look at ford transit forum
    hope you get it sorted
  • JayOutdoors
    JayOutdoors Forum Participant Posts: 572 Participant
    edited December 2018 #10
    Just a thought - When the problem gets sorted it might be worth trying a premium fuel if you don’t already use this.  Good luck.
  • cakks
    cakks Club Member Posts: 7
    edited September 2025 #11
    Just having a similar problem with our Ford Chausson, 2ys 9 mths of trouble free motorhoming, then suddenly into limp mode. "Low fuel pressure" flashed up on the dash, then "service vehicle soon" came up.
    Local breakdown guys could not see any stored fault codes.
    Had it recovered to the most local Ford Transit centre.
    8 weeks later, new fuel pump, injectors, fuel rail, system all cleaned out, and with input from Ford Technical, we still have no motorhome.
    Guys in the service centre doing all they can, but my confidence in Ford is now at an all time low.
  • cakks
    There was an error rendering this rich post.
  • eurortraveller
    eurortraveller Club Member Posts: 7,297
    Eight weeks waiting . Wow! You are more tolerant than me.
    Though I must say that the boys at a local family owned repair shop here in small town Cornwall make a regular, but honest, living replacing EGR valves and injectors on anything with a Ford engine which arrives at their workshop in limp mode. One day to order the parts, then fit them and road test next day.
  • cakks
    Ford must have a lot of issues that need their field engineer to visit the actual vehicle, it's taking 3 weeks to get them to attend in person.
  • cakks
    Now 18 weeks, was told it was repaired 5 weeks ago, picked it up and drove 193 miles before it went back into limp mode with orange spanner light, now in another branch of the same Ford Transit dealership, and no further forward !!!
    Suggest you contact the club's legal dept for advice.
  • cakks
    For info, still not got it back …………… Ford have now moved it to a different dealership.
    peedee Forum Participant Trusted Posts: 10,124
    Have you tried contacting Ford UK about the problem?
  • cakks
    sure have, been in weekly contact with them since October, get the standard repsonce of "waiting for technician availability", as the warranty expired at the end of October I'm hoping they will honour it.
    In addition to this, Ford will not offer an extended warranty because it's a motorhome, however I have a press release from 2017 where Ford announced their commitment to motorhomes by stating that they will give a 5 year warranty to all Trigano Ford Transit based motorhomes, but no-one in Ford UK will confirm or deny their ongoing commitment.
