Help - water leak Flojet
Jen2thehen
Jen2thehen Forum Participant Posts: 29 Participant
edited March 2018 in Caravans #1
Hi
Can anyone advise. Our first run out of the year and when we switch the water pump on (Flojet) it is leaking from a white plastic bottle (looks like a rabbit drinking bottle) next to the Flojet waste water pump. We have tried to seal with gaffa tap but still leaking. Can’t seem to find online what this piece of kit is for replacement.
Any advice greatly appreciated.
  • ForestR
    edited March 2018 #2
    I assume you mean water pump not waste water pump and I guess it's a Swift or Coachman caravan. If this is correct then it's probably the surge damper that's leaking. This smoothes out the supply of water. I think a replacement Truma is over £100 or you could try a Whale at about £30 which may work
  • MotorHomer2
    MotorHomer2 Forum Participant Posts: 41 Participant
    edited March 2018 #3
    Why not contact them direct?
    http://www.xylemflowcontrol.com
    I have spoken to them in the past and they are very helpful.
