Spare motor home wheel and tyre
Nicki Burgess
Nicki Burgess Forum Participant Posts: 14 Participant
edited February 2018 in Motorhomes #1
Hi , we live in Bristol and have a 2017 Bailey 794 T motor home that does not come with a spare.
we have decided to try to get one but cannot find a company who will supply and fit the tyre with the steel vavles
 Can anyone make any suggestions or have used someone who can do this
Thanks
    Tinwheeler Forum Participant Trusted Posts: 24,275
    edited February 2018 #2
    We bought a wheel on eBay, a budget tyre from our local depot and the steel wheel bolts from our local Merc vehicle dealership.
    A carrying bracket was fabricated by a local workshop, a wheel cover was purchased from Amazon and a bike lock from The Range.
    Watch your payload is my tip.
  • Nicki Burgess
    edited February 2018 #3
    Hi thank you for the info
    who fitted the tyre to the wheel ?
    edited February 2018 #4
    The tyre depot where we bought the tyre.
    We went in with the bare wheel and came out with the tyre fitted to it.
    edited February 2018 #5
    As you live in Bristol, have you been to Baileys parts storewink
    edited February 2018 #6
    edited February 2018 #7
    edited February 2018 #8
    Bring back the Talbot Cabs where the spare wheel fitted in the engine compartment,so much for progressive designundecided
  • KeithandMargaret
    edited February 2018 #9
    Many MH owners take just the 'spare' tyre with them especially if weight is a problem.
    If you are going to rely on the Breakdown service changing the wheel for you then that makes good sense.
    It's sourcing a new tyre that usually defeats the breakdown people - MH tyres often have to be ordered and the delay in getting them means you could have a very long wait - especially when abroad.
    We take a spare wheel, kept in the garage, and wouldn't be without one in the UK or abroad - the 'gunge' option is as good as a chocolate teapot if you have anything other than a minor puncture - any tyre damage is rarely repairable.
  • H B Watson
    edited February 2018 #10
    Personally I hate being without a proper spare, I keep looking at getting one, there are several companies who will supply them just Google for it. My problem is simply where to put it when the MH isn't designed with one. I wish you could get a space-saver but quite understand the problem with weight,
    DavidKlyne Club Member Posts: 14,735
    edited February 2018 #11
    You can buy steel rims from places like this They will also fit a tyre. One thing I noticed is that the rim only has a rubber valve when it should really be a heavy duty one.
  • ABM
    edited February 2018 #12
    Ah  yes,  that  takes  me  back  to  the  glories  of  a  Bay Window  VW  !!  Mine  had  the  spare  inside  alongside  the  bed  !  Took  me  all  of  2  nights  of  my  first  holiday  to  work  out  where  it  belonged.  One  bracket,  four  bolts ( I think )  and  a  steady  hand  with  a  drill.  And  there  it  was  A  Front  Mounted  Secondary  Bumper  !
    Oh  for  those  simple  days  !!
    edited February 2018 #13
    Luckily, our MH had a towbar and we were able to have a bracket made to fit the towbar, HBW, so the wheel was carried against the rear wall of the MH. Again, weight was a consideration.
    Cornersteady Club Member Posts: 15,479
    edited February 2018 #14
    just out of interest  but I never gave it a second thought and just assumed that all MHs had a spare so interested to find out this wasn't the case. How many do and how many don't? It appears from the replies that many want one? Also do people carry inflation kits? And if you had a spare I would imagine it's quite difficult to use a jack because of the weight? Some caravaners myself included, have ditched the screw up one and carry a hydraulic jack (in the car), do you do the same?
    edited February 2018 #15
    The supply of a spare wheel varies, Corners. Our current Peugeot has one which winds down. It is the original Pug chassis with no bolt on Alko extension. A previous Fiat, 10 years ago and almost it’s brother, with the Alko extension chassis also had one in an underslung carrier which bottomed on a ramp.
    Our Merc on the original Sprinter chassis had no spare but came with a compressor and can of goo. However, later models had a spare wheel.
    Sometimes, it depends on the chassis as the Alko may not leave space for a spare and, similarly, the placement of underslung tanks may intrude into the required space. Also, it became fashionable some years back not to have spare wheels on anything. Fleet operators of panel vans may not want spares as they could find it more cost effective to send a rescue crew out to white van man if he gets a puncture. Therefore spare wheels may not be standard on the very same vans on which MHs are built.
    I have had two compressors in MHs and neither proved capable of reaching a high enough pressure for the requirements of the MH.😤
    Due to the weight of the wheel and difficulty of changing at the roadside, it will be RAC Arrival for us in the event of a puncture and hydraulic or trolley jacks are surely the way to go.
    edited February 2018 #16
    thanks TW
  • ABM
    edited February 2018 #17
    Similar to  our  Cornish  Friend,***  my  Ducato  has  the  wind  down  spare  which  I  will  rely  on  Green  Flag  to  reach  &  fit  should  one  of  my  wheels  need  attention  --  I'm  regularly  told  "yer  too  old  n  K######ed  to  do  such  things  yersen" embarassedsurprised  !!
    As  for  the  inflation  I  use  a  Halfords  12v  jobbie  which  does  ok,  only  takes  about  two  to  three  mins  to inflate  to  65p.s.i.  but  will  stop  automatically  when  it  reaches  that.  It  also  stops  if  I  try  to  inflate  more  than  2 to  that  pressure  without  giving  it  a  rest  !!
    ***  Have  to  be  careful  with  TW,  'cos  I  did  threaten  him  with  my  company ( innocent )  this  year  &  I'll  be  darn  sarf  wes'  twice  this  year  and  he  might  get  the  Border  Patrol  out  undecided
    edited February 2018 #18
    undecidedtongue-outlaughing
    peedee Club Member Posts: 10,080
    edited February 2018 #19
    Like K&M suggests I just carry a spare tyre strapped to my bike rack when touring across the channel. In the UK I take my chances.
    edited February 2018 #20
    I've got one on a cable under the van. Wound it down to check tyre pressure and see how the system worked. OK in the sunshine on the drive. Not so sure about a cold wet night at the roadside. A Mayday job, methinks.
  • H B Watson
    edited February 2018 #21
    Oddly enough I've just stumbled across a bracket which fits on a tow bar, could be a good solution when I'm not towing anything.
  • ABM
    edited February 2018 #22
    " A Mayday job,  methinks.  "
    And  with  Age  comes  Wisdom ( sometimes  anyway  laughingwink !!  )
  • mike132
    mike132 Club Member Posts: 79
    edited February 2018 #23
    I am definitely in the 'have a spare wheel and tyre' brigade especially on the continent.  From memory I think ATS will fit steel valves but you have to supply them yourself.
  • Apperley
    edited February 2018 #24
    I was able to have an Alko spare wheel carrier fitted to the Bailey Alko chassis. Fits at the rear. I need to feed the water boiler drain pipe through the holes in the rim so I can drain the boiler. I just don’t want to rely on the fix and go kit, which can only repair a very small puncture and one is not supposed to drive long distances after the inflation.
    The other problem with a fix n go kit is (I am reliably told by a KwikFit guy) the tyre can’t then be repaired and needs replacing. So your back to all the sourcing problems, and you need to get another fix n go kit for the next puncture.
    Other things to consider though, I bought a breaker bar with the correct nut size socket otherwise it’s difficult to get the wheel nuts off. I have a better jack and a cordless compressor as my tyre inflator using the 12v plug won’t reach the rear tyres! Or
    edited February 2018 #25
    For those that don't have a spare wheel, in the U.K. the RAC offer a puncture call out service, free to members, £30 otherwise last time I checked.
  • BlueVanMan
    100 Comments Name Dropper
    edited February 2018 #26
    in 2009 I had a rapid tyre deflation (due to a valve failure) on a Hymer Van 522 at a particularly busy section of the M6. We had a spare and a green flag operative fitted it within about an hour.
    Three lessons learned :-
    Mark 5 transits have/had a valve/tyre issue.
    It was a very dangerous procedure to change the tyre due to the heavy traffic even though we were well onto the hard shoulder and the rescue truck had beacons etc so.
    We would never be without a spare tyre. The time to factor this in is a the time of purchase not afterwards !
  • KeithandMargaret
    edited February 2018 #27
    If you have a puncture in France the best way to get on your way again is to change it yourself.
    A few years ago we were on an Aire in France and a fellow Brit pointed out that my front tyre looked 'a bit low'.
    It had a slow puncture, a nail was in it, and between us we changed the wheel in a few minutes.
    I took the tyre to a local garage and they repaired the tyre, charged €10, and we were on our way in no time.
    If we hadn't had a spare wheel we could have been standing around for hours waiting for a recovery vehicle.
    If you are going abroad then calling the recovery people should be your last thought not your first as they are very thin on the ground especially at weekends and the frequent public holidays.
    My, and possible your, lack of foreign language skills to summon the recovery may also delay their response.
    edited February 2018 #28
    In thirty years I have needed breakdown assistance 4 times and I have never waited more than 2 hours for help. Once was on a Sunday and once was on a public holiday.
