Bailey Pegasus rear grabhaindle led replacement
I have a Bailey Pegasus 2 Bologna. The left hand rear grab handle led has gone out. Does anyone know how to fit replacement led into the handle. I can see where the right hand handle mounting screws are inside the bathroom behind the toilet but the left hand side must be behind the shower.
There must be a way to replace the bulb without removing the handle ![]()
Any Advice please
Hi MollysMummy, Heard from Bailey parts they told me to contact a Bailey dealer. I did and their work shop told me to remove the two grey plastic caps at the end of the handle and this would allow the bulb to slide out. It worked. however I also had to remove the rear bumper corner moulding get to the wiring, where I found a corroded connector. I remade the connection and Bingo the light works again.
Cheers for the encouragement.
