Hot water
Youngbunch
Youngbunch Forum Participant Posts: 54 Participant
edited February 2018 in Motorhomes #1
autotrail 2013 and looking for some pointers
we are mostly on hookup when away and heat the water up straightaway. However, every so often (can vary from 5 mins to 30 min) the pump kicks in for 5 seconds. What I have noticed is an overflow drip of hot water outside under the water heater.  So I am thinking that the hot water is overflowing needing the pump to top up the tank
This is ok through the day but not great when trying to sleep at night !
Any suggestions what I should investigate ?
    edited February 2018 #2
    Could be the drain valve leaking, until sorted turn off pump at nightwink
  • KeithandMargaret
    edited February 2018 #3
    I haven't got an Autotrail but my MH did a similar thing a couple of years ago.
    Check that there isn't a leak from any of your sink taps (there was with mine) with water running or seeping down the plastic pipes, and if there is it could be caused by frost damage, old age or just the clip holding the pipe has come loose.
    Occasionally the tap itself leaks (they shouldn't but they do) and may need replacing – they aren't cheap.
    The short burst of the pump could also be due to the rubber gasket either perishing (which will need replacing or hopefully just cleaning) but try tightening the holding screws which may be loose – see video of my pump (turn sound up)
    If it is the water heater leaking it will probably need an expert to check it over but tighten any screws you can see and that may hopefully sort it out before taking it to the expert.
    Of course, what I've written may be a load of rubbish and if it is I apologise.
    Video -
  • Justus2
    edited February 2018 #4
    Our pump sometimes re pressurises the system during the day. Various caravans have also done so previously. We have always turned our water pump and our hot water off whilst out for the day and also whilst asleep as a precaution. Caravan water fittings are not always the most secure and can, if a joint fails completely, empty your entire tank into a bed locker.
    edited February 2018 #5
  • Youngbunch
    edited February 2018 #6
    This is the temporary solution as I’m a light sleeper and it was driving me mad.
    its going into the dealer for an unrelated issue in a few weeks and has been added to list of issues to be checked/fixed as we have an extended warranty that I hope covers it
    I have gone round and checked all screws
    peedee Club Member Posts: 10,041
    edited February 2018 #7
    I agree, is it actually fully turned off? It maybe worth flicking it open for a few seconds and shutting it again?
  • Youngbunch
    edited February 2018 #8
    Been away 2 nights and not an issue. The water was drained off 2weeks ago so maybe just a ‘purge’ of the water pump has cured it.
    will be using more over the coming months so will keep an eye (or ear) on it.
