Water pump - issue airlock ? Motorhome
Second time we have used our Adria Coral 680st , but we have no water coming out of the taps
As we are new to Motorhome, I drained the water tank and left the taps on to stop pipes bursting during the winter , but did not run the pump to force out the water out of the pipes .
When I turn the pump on I can hear it running , open the taps but air comes out with a splattering of water . I have left it running for several minutes but still no water just lots of air .
The water tank appears to have a pipe which I presume the pump sucks out the water from the tank . But there does not appear to be any suction. I have poured water down the pipe using a canister and for a brief second we did have water out of the tap , but again no suction after
So I assume we have an air lock in the pump but how do I resolve ?
I do not think you have an airlock more likely an air leak on the suction side of the pump. could be a cracked hose fitting or if you have a filter with a glass sediment bowl that could be cracked. you could try an old trick by closing all taps except the shower then take off the shower head and with the pump running suck as hard as you can on the shower hose end this will help to draw water up from the tank to the pump but will only work if you do not have the leaks mentioned above. It has worked for me many times. goodluck
1 -
Thanks very much did not know about the shower trick .. it makes sense . Got one mouthful of water then just air . So yes your right I must have a leak from tank to pump . So I will try pouring more water down the tank suction hose with pump running and tap open , and then check for leaks .. my pump does a a small glass cup on the inlet would that be the filter , it's a but awakward becuse you cannot get to it as its flat on the floor
thanks for your help with this
regards nick
0 -
I had an intermittent problem similar to this, it turned out to be air being sucked into the plastic pipes near the surge damper .The pipe was cut a little short and was not pushed into the coupling as far as it should have been. It only happened about once in approximatly every 20 nights use and was a real pain. Have a good push and make sure all the plastics pipe ends are fully home. Good Luck
0 -
If you did drain the hot water tank, did you remember to close the drain down valve? Check under the van to ensure water isn't running out as fast as the pump tries to push it into the system. Most of us have done this at least once!
0 -
Thanks Your advice was spot on about sucking on the shower hose worked for me when I had no flow and the pump running continuously on my Delaware. I probably created my own problem when I drained the system hence creating a air lock.
