Electrical Problems - Majestic 125
cyberyacht
edited September 2017 in Motorhomes #1
All changes involve teething problems but I found it disconcerting when I went to unplug the orange cable ( sorry Merve) of the MH on the driveway. The battery was red hot. The caravan had a set of three rocker switches on the PSU, water, heating and charger.
The MH panel does not appear to have a separate switch for the battery charger, so I assume it operates from the master switch. Not that this relates directly to the problem. I'm not too good on electrics. Any suggestions folks?
    edited September 2017 #2
    Just a thought, is it a battery that needs topping up with distilled water? i think they tend to get hot when running low on water,if the m/cv was serviced?,it could be a faulty charger
  • Hallsontour
    edited September 2017 #3
    I'd have this checked out CY. I had the same problem with my Elddis van a couple of months after I bought it. On your van I'm certain the charger works when it's plugged in, you don't need the master switch on for it to charge the battery. When on hook up only your Lesuire battery will be charged, NOT your engine battery. My van is Sept 2015 Reg.
    My lesuire battery kept going flat and one day whilst away camping we'd gone out for a few hours and when we came back the battery was almost on meltdown. The smell was awful too. At first Marquis blamed a faulty battery and replaced it FOC but a couple of weeks later I got a recall on the van from Elddis. It was due to the water tank  frost 12v heaters going on and flattening the battery. Elddis had wired them in wrong and they didn't go off with the master switch. Anyway, they took the van back and rewired the heaters putting an extra switch for them in the wardrobe. I've since been under the van and disconnected them both so they now can't come on at all. I also had a solar panel fitted to trickle charge both batteries as the cab battery runs down after 3 weeks of no use in the winter due to the drain caused by the alarm. Since I've sorted those little problems out I've had no further battery issues in over 18 months.
    edited September 2017 #4
    edited September 2017 #5
    I've since taken the leisure battery out and put on a charger in my garage. Started out at just under 5amps, dropping to 4.5 amps after two hours, but 14 hours later was still charging at 4.5amps. After disconnecting it showed a voltage of 12.7v but half an hour later it has dropped to 12.5v. It therefore seems that it is not taking a full charge which would tally with the readout from the solar controller. The controller, before the van was connected to mains hookup, was showing it as charging, rather than float charge despite the voltage showing 12.75 which suggests that the battery is not accepting the charge properly and which tallies up with the overheating when connected to EHU. Whilst not completely kaput, it seems that the battery is heading towards Norwegian Blue Parrot status so I'll have to bite the bullet and buy a new one.
    edited September 2017 #6
