Nose weight issues/concerns
Southwest123
Southwest123 Forum Participant Posts: 24 Participant
edited August 2017 in Towcars & Towing #1
I am finding it very difficult to achieve the desired nose weight. The caravan is. Swift Challenger 550se - I need to achieve 85kg, but the weight is close to 100kg ( car is a Volvo V70). At the moment I have two 7kg gas cylinders and a spare wheel in the front locker and a 110 amp battery in the battery box,. Plus a motor mover. I can get close to 85kg by removing one of the cylinders (leaving this at home) and placing the spare wheel just over the axle on the caravan floor. I am still relatively new to touring and was wondering whether I should move weight E.g spare wheel further back beyond the axle, but this doesn't feel right.
I would add that when I got the weight right, the set up didn't feel right, the car/ caravan combination prefers the higher nose weight. Any advice or guidance welcome.
  • Broadside
    Broadside Forum Participant Posts: 125 Participant
    edited August 2017 #2
    Hi. I have a Swift Challenger Sport 564 and I tow with a Serento 2.5D XT. The max permitted weight on the tow bar is 120kg and the recommended (manufactures) nose weight of the caravan is 90kg.
    I tow with a nose weight of 90kg and it tows comfortably with no problems but to achieve this nose weight I have put as little as possible in the front locker, ie only one cylinder and just bits and pieces, hoses, toilet fluid etc. If I take a spare cylinder I take it in the car as well as the awning, in order to keep the nose weight down.
    This set up changes depending on the tow car, but I advise to keep the nose weight down to the recommended weight and to check the max weight permitted for your car/tow bar. I personally do not put any weight behind the axle to counter the nose weight as this can cause problems ie unsteadiness.
    Putting weight over the axle should not cause any problem, such as spare wheel, awning. You should be able to check the manufactures  max permitted nose weight on line.  Hope this helps
  • Southwest123
    edited August 2017 #3
    Broadside - thank you for your guidance. I will remove the spare gas cylinder and move the spare to over the axle, may even keep the spare in the car. smile
  • Broadside
    edited August 2017 #4
    Fine, but make sure you check the manufacturers recommendations for the nose weight and tow bar/car weight. Its sometimes a matter of trial and error.   Good luck and happy caravanning
  • dmiller555
    edited August 2017 #5
    You are carrying a lot of gas, at least by my standards. Would it be possible to replace one cylinder with a small back-up cylinder in order to reduce the load?
    edited August 2017 #6
    We had a Bailey Valencia S1 and struggled to get the nose weight down to 100kg. The ex-factory nose weight was 86kg so you can see the problem. In later models they moved the gas bottles to the centre of the van which probably helps.
    The only way we could get the weight down was to shift some heavy items to the back of the van. This is not ideal from a stability point of view but in our case it appeared to make little difference to towing stability.
    edited August 2017 #7
    I have never been overly concerned about moving heavy stuff towards the rear. My experience is the main thing is that the centre of gravity is forward of the axle and noseweight is correct.
  • Lutz
    Lutz Forum Participant Posts: 1,691 Participant
    edited August 2017 #8
    I agree with EasyT. So long as you don't overdo things and load something like 100kg or more right at the back of the caravan the outfit should remain perfectly stable.
  • Southwest123
    edited August 2017 #9
    Thank you to everyone for the advice and guidance. I have decided to go to just one gas cylinder, may be a Calor Lite (although these seem quite difficult to source). The spare wheel will be securely loaded just over the axle. I think that I may have also taken the reading incorrectly, in the the caravan was on a slight slope - this may have resulted in an incorrect reading. I am also going to a local weigh bridge to check the overall weight of the unit.
    Again - I do appreciate the guidance provided.
    edited August 2017 #10
    How much gas you need to carry depends largely on whether you will be using electric hook up all the time and how long you are away for.
    I am always on EHU and so use very little gas. A 3.9kg bottle would last me 80 nights. When I was only going away for 10 weeks I only carried the one bottle and would replace every Christmas. At £16 a refill I was not concerned if there was a couple of quids worth of gas left in the bottle at exchange. As I actually need the noseweight on present caravan and we are away 120 nights I carry two 3.9kg bottles. They are not a great deal different in weight to Calor lite when full. Calor Lite does seem to be more difficult to obtain refills for on a like for like basis.
  • Deedlydave
    Deedlydave Forum Participant Posts: 16 Participant
    edited August 2017 #11
    Glad I trawled the discussions as I am having same issue as SW123.
    We've changed from a motorhome to a caravan (Elddis Affinity 530 with 4WD Tiguan for towing) and picked up the van with no gear in it apart from the leisure battery (stored forward of axle) and gas bottle in front locker; the spare wheel is hung just behind the axle. Motor mover (30kg) is in front of axle.
    Van, car and towball limits are all 100kg while the 7% calculation comes out at 98kg. I checked nose weight (Milenco guage) and it came in near to 110.
    We don't yet have an awning but today I took all our other "stuff" (about 90kg) and placed it over the axle, avoiding rear washroom, and got weight down to 105kg.  I don't want to start removing battery and gas bottle for travelling, or place stuff in washroom as we are new to towing and want to keep outfit as stable as possible - but have we any other options?
  • Lutz
    edited August 2017 #12
    Is there no space to store anything in transit between the axle and the rear washroom?
  • Deedlydave
    edited August 2017 #13
    Having spent today moving "stuff" around, including cushions off front sofas, so there are no additional items in front of axle, I still can't get nose weight below 105kgs - I might move everything into washroom!
  • xtrailman
    edited August 2017 #14
    Remove the wheel from the front locker and put it behind the axle, if your layout has a fixed bed then place it as far to the rear as possible.
    Also the mains lead can easily be placed behind the axle, trust me the caravan will not be unstable, the reason your caravan is so nose heavy is partly due to the lack of fitments behind the axle, simply designed with too much weight up front.
    I have practically everything behind the axle with my U1, just make sure you have the recommended 5 to 7% nose weight.
    My present caravan a swift has the opposite problem due to the 40kg I carry with the bike rack, so my front locker is full with heavy gear, not much under the fixed bed, just to get up to 85kg NW.
  • Merve
    edited August 2017 #15
    Or even a Safefill? All you need is one Safefill.
  • Nige W
    Nige W Forum Participant Posts: 9 Participant
    edited September 2017 #16
    Brilliant advice Broadside. The Club does not actually recommend putting a gas cylinder in the car due to health & safety.
  • EJB986
    edited September 2017 #17
    If you do carry a cylinder in a car please ensure it is secured upright.
  • rjb
    rjb Forum Participant Posts: 118 Participant
    edited September 2017 #18
    If your water heater/boiler is under front seats be sure to drain it that will help nose weight
  • podimore
    podimore Forum Participant Posts: 2 Participant
    edited September 2017 #19
    Hi Southwest 123,  We have just bought an elegance 580 and I seem to be able to get the 85 Kg nose weight I am also looking for, with normal loading.  This includes mover in front of axle and 6 Kg light gas in locker.  But the big difference to the Challanger is that the spare wheel (22 Kg) is in an underslung AlKo rack just behind the axle. You might consider a retrofit as I am sure all the chassis are fitted to take the rack.
    Our last van, a Clubman SE had the same spare wheel arrangement and easily achieved ideal nose weight.
    Happy tugging
    Martin
  • Lutz
    edited September 2017 #20
    Putting things into perspective, I find it a bit strange that some people religiously refuse to put anything behind the axle, but are perfectly happy with having the underslung spare wheel carrier there and a rear washroom which, with all its fittings, probably weighs more than most payload that one is likely to place inside the caravan.
    edited September 2017 #21
    There's not much you can do about repositioning an end bathroom, but why purposely build a pendulum?
  • kentman
    kentman Forum Participant Posts: 147 Participant
    edited September 2017 #22
    Having read the previous comments on this thread in which members talk about where in the caravan they put their awning, etc, I wonder whether there is a general appreciation of how little one can carry in a modern caravan.  We have been caravanning for 37 years, beginning with a 1974 Sprite Musketeer and never used to worry about overall weght so long as the noseweight was within proper limits.  Last year, after 6 week trips on the continent, some friends and ourselves both experienced broken axles on our identical Bailey Unicorn Vigo series 3 caravans.  They were repaired free of charge by Bailey but we were both told that we had overloaded them.  This led me to look much more deeply into the matter of weight.  Most caravans are advertised as having a payload of between 150-160 kg.  If you fit a leisure battery and motor-mover, this comes down to around 95kg which is pathetically inadequate.  I have changed our caravan for a Coachman VIP which I have had replated to 1700kg which gives a payload after battery/motor-mover of approximately 180kg (note: series 3 Baileys cannot be replated to a higher payload).  I have taken the Coachman to a weighbridge and even with the replated payload, I have to put the awning, waste container, water container and television in the car.  I have also had to tell my wife to stop our previous practice of stocking the caravan with food and to just take essentials.  I suspect that we have all been led astray by the volume of storage provided in our caravans, including large fridges, and that many caravanners are, as I was, seriously overloading their caravans.
  • onepjg
    onepjg Club Member Posts: 282
    edited September 2017 #23
    unicorn max weight upgrade
    I thought you could upgrade the series 3, but if you broke the axle,
    even an upgrade wouldn't be any good.
    I personally think motor movers will push the majority of van weights over the limit, once people
    pack other stuff
  • DS3
    DS3 Forum Participant Posts: 108 Participant
    edited September 2017 #24
    There is nothing wrong with heavy items behind the axle/s, as long as they are low down and the nose weight is at the correct weight, then it will still be stable. Two heavy gas bottles in the front locker is too much in my experience. Unless you don't use EHU then just one 6kg bottle is ample, don't forget that most sites stock gas if you do run out. Maybe try to get a gas lite bottle if you can find one.
    One thing I am happy about is people that are actually concerned about nose weight, many don't even know what it is let alone check it.
    Just one thing, my Volvo V70 had a maximum nose weight of 90kg, but it was a 2015 model.
    edited September 2017 #25
    When i was at one of the ncc shows,i was looking round one of the stands,and overheard a "salesman?" adviseing that as the person he was talking to had a Discovery there was not a problem with any nose weights as he could put 150kg on his tow hook ,when excused myself and interupted asking how could that be when on the Alko coupling there is moulded a 100kg max weight limit he had to look as he had not heard about itsurprised
  • DS3
    edited September 2017 #26
    Oh yes. We are amazed at how much stuff some people carry in their caravans and cars with total disregard for weight limits, in fact I was told I was an idiot for suggesting such things and that a car and caravan are not trucks so why should they worry about weight limits, just chuck everything in there. I left the group, I do not want to be associated with morons like that.
    We put ours on a weigh bridge with just the battery, motormover and a gas bottle in there, then weighed everything we put in it. We dress for a week, clothes can be washed and take the bear minimum because we have the awning over the axles.
    We have a limit of 155kg, the awning is 35kg including poles so not much left for everything else.
