Hymer starter battery drain
Phil hr
Phil hr Forum Participant Posts: 9 Participant
edited August 2017 in Motorhomes #1
hi, don't know if I'm on the right site for tech problems as I am a new member, but I'm sure someone will tell me if I am not.
anyway, the problem I've got is my hymer b578 starter battery goes flat after a few days.it's a new battery but something seems to be dragging it down,I've switched off the living battery's on the transformer and made sure pioneer radio is off, although it's not connected via ignition circuit. Any help appreciated.
thanks Phil hr
  • Vicmallows
    edited August 2017 #2
    Hi, This discussion category is fine for your query.
    I don't know anything about your MH, so my comments are general.
    Unless your 'new' battery is faulty, something is clearly draining it. (Even a 1Amp  continuous drain would deplete a typical battery in less than 3 days).
    You say you have "switched off the living battery's on the transformer". I don't understand this.  I assume you are saying you have switched off the battery charger which would charge your domestic batteries when on EHU?
    I would expect the domestic batteries to be isolated from the starter battery when the MH engine is not running.   Do the domestic batteries also discharge over the several days, or do they remain fully charged?
    (We can then progress from there with suggestions)
  • beero
    beero Forum Participant Posts: 38 Participant
    edited August 2017 #3
    Remove one terminal of the battery. When you go to reconnect it see if you get slight sparks as you touch the clamp to the post. If you do then something is drawing current. This can be measured if you have and know how to use a meter. Make sure your doors are not open as the interior light will show as a spark.
    You can then remove fuses one by one to see if you can isolate the problem.
    Make sure you have the radio code before you disconnect though.
  • Phil hr
    edited August 2017 #4
    Hi, the living battery's hold their charge ok ,its only the starter battery drains down. I Will check with a meter what  current is being drawn with everything off and try and pull fuses to isolate  problem. New battery on charge at moment .will get it checked Monday.
    thank you both.
  • EJB986
    edited August 2017 #5
    It's fairly normal for the starter battery to drain in perhaps two to four weeks with the draw from alarms and other live systems.
    The leisure battery doesn't normally have anything live so will stay charged for months.
    Edited as we cross posted, I only check voltages unless I think there is an undue draw on the battery which I have never had cause to do!
    HTH.
    edited August 2017 #6
    edited August 2017 #7
    I have certainly read similar findings BB
  • Phil hr
    edited August 2017 #8
    Sorry I'm so long getting back about this problem.
    i found the current being drawn with everything switched off was 800milliamps, much too high. Traced the problem to a pioneer radio which was wired live all the time,not connected to acc of ignition switch.
    now wired correctly I hope this solves the problem. Thanks.
  • Bakers2
    Bakers2 Forum Participant Trusted Posts: 8,659
    edited August 2017 #9
    Nice to hear you've sorted the problem. Good to get feedback. Happy touring 😆
    edited August 2017 #10
    edited August 2017 #11
    That's amazing and by my reckoning definitely a design oversight. After all, if you left a car at the airport and it had a 0.8 amp current drain ithe battery wouldn't last a week.
    I don't use my entertainment system but a recent post discussed the fact that the radio on many Peugeot/Fiat models would switch off after about 15 minutes. There are work-arounds but I guess the feature was built in to avoid the current drain that you have experienced.
    edited August 2017 #12
  • John 11
    John 11 Forum Participant Posts: 2 Participant
    edited October 2018 #13
    just read the issue with flat starter battery's. I have a Carthago with a Pioneer head unit and suffer the same problem. Seems Carthago had a fix for this for 2018 vans, does anyone know what it was?
