Dometic toilet water running into bowl
edmundl
edmundl Forum Participant Posts: 37 Participant
edited August 2017 in Caravans #1
Hi please can anyone help when I flush the toilet in our Lunar Cosmos it flushes fine but when I release the flush button the pump stops but flush water continues to trickle into the bowl for quite some time after
  • Merve
    edited August 2017 #2
    Errr, mmm, never heard of that one. It's got to be something to do with the tube leading to the flush I would say. When you flush, does the flush start immediately or is there a delay before you see the water??
  • edmundl
    edited August 2017 #3
    Hi thanks bit of a strange one yes flush water comes through as soon as you press the button, only thing I can think it could be is some kind of syphoning action
  • heddlo
    heddlo Forum Participant Trusted Posts: 1,057
    1000 Comments 500 Likes Photogenic Name Dropper
    edited August 2017 #4
    Our Dometic toilet does this frequently!  We have found it half full on one occasion.  It only seems to do this when the flush tank has been fully filled; as soon as some water has been used it then behaves correctly.
  • edmundl
    edited August 2017 #5
    Thanks will try only partially filling it and see how it goes
  • Heethers
    edited August 2017 #6
    When we had the Lunar clubman our flush ceased to work, dealer tried everything, in the end dometic sent a new loom, which cured the problem. It needed the toilet to be removed to fix it so why it was out l insisted on the uprated pump which they did after l had said the original was not fit for purpose and quoted heath issues. The flush was far better on the uprated pump
