Hartal Door Lock
scotts
scotts Forum Participant Posts: 48 Participant
You know having just spent a nearly £29k on a new caravan (Swift Conqueror) the biggest bug bear has to be the locks & lessons are not learnt. 1st it was that front locker with the new mechanism to a single central lock - badly executed, When I opened it, most of the Hartal lock fell to bits all over the road & the crucial clip was balanced by a drain cover. After I put it back together & tightened it all properly its now ok. On Sunday I was checking ready for "the trip" & after turning off the alarm opened up (this is the New type lock, also from Hartal) to notice that the key just turns a full 360 + keeps going in either direction. So I went to the dealers unable to lock it & showed them. Bemused, they went about replacing it, as they had a spare (as a temp measure) . Guess what - this also has the same issue. So in a nut shell i'm vanless. The reason for my rant is that I had sticking problems with the similar locks on older models. There is clearly any issue - Stop using us a guinea pigs please
