Jockey wheel for A-frame
Hatchet
Hatchet Forum Participant Posts: 14 Participant
edited June 2017 in Caravan & Motorhome Chat #1
Can anybody recommend a jockey wheel to fit a Smart Tow A-frame? The frame is 25mm square steel box but can't be drilled due to the fact that it telescopes when not in use. All the ones I see on E-bay are for 50mm box.
    peedee Club Member Posts: 10,032
    edited June 2017 #2
    Why do you need it? Check out what I do at http://www.wheelgotravelling.info/OurTips.html
  • Hatchet
    edited June 2017 #3
    Thanks for that peedee - seems a solution.
    Cheers
    edited June 2017 #4
    Worth trying to see if it suits you after all it will cosr your nothing,  I use this method.
  • Hatchet
    edited June 2017 #5
    I've now had chance to try this out peedee and it works brilliantly. I us a luggage strap that has a hook on each end and an adjuster in it which allows me to make fine adjustments so I can drive the car to position the coupling directly over the ball. So many thanks.
    edited June 2017 #6
    Pleased to read it worked out ok for you and using an adjustable strap is a good refinement on the method. Thanks.
