Problems Draining Hot Water Tank
SteveL
edited May 2017 in Caravans #1
I know there are various arguments running as to if this is necessary when moving on, however, we almost always do.
This tour it has refused to drain each and every time. I have opened drain valve and taps, but it refuses to drain. The drain valves seems to open as there is an initial few drips before it dries up. On bumping out of the campsite it starts draining and from the amount required to prime it, at the next site, it seems to all come out. Our system is an Alde.
My question is do you think it is just the valve sticking, or not opening properly, or is there some other vent that is not performing.
It is not a significant problem at the moment, however come the winter I want to be sure it has fully drained down, and this is difficult when you can't monitor it,
  • ABM
    edited May 2017 #2
    SteveL,    I  mean  absolutely  nothing  Personal  with  the  Following,    { Honest embarassed  }
    Open  the  drain  valve  first  then  just  ONE  tap  set  to  Hot  obviously  ( I'd  use  the  shower  head  if  its  small  enough  )  then  BLOW  like  blazes  back  down  the  tap.  If  its  just  a  tad  sticky  it  might  well  get  blown  open  before  you  need to  do  anything  else  wink  or  even  surprised !!
    B
    edited May 2017 #3
    edited May 2017 #4
    I open the sink tap wide half way between hot and cold. Dunno why not just the hot. Habit?
    I presume that you do similar Steve?
    Cornersteady Club Member Posts: 15,467
    edited May 2017 #5
    we had a similar problem a good ten years or so now. From what I member the local dealer/service person seems to know exactly what part had gone wrong and fixed it in minutes, something to do a non return vale near or on, the actual hot tank. When you open the drain, the pressure drops in the pipes and allows this non return value to open and the water comes out of the tank.
    edited May 2017 #6
    edited May 2017 #7
    Thanks all. I will try blowing ABM it's worth a try.
    BB On our Unicorn it is an internal pump, which is safe to run dry, so I did try that, unfortunately to no avail.
    Yes ET that is exactly what we do.
    CS I am taking it in and leaving it with them to sort out the Satellite dome in a few weeks, so if ABM's fix does not work I will ask them, hopefully they will be as wise.
  • ABM
    edited June 2017 #8
    Steve,  If  You  can leave  it  till Friday  there  should  be  lots  of  Hot  Air  gong  spare  by  then  embarassed  OK  OK I'll  get  me  coat,  tara  for  now  !!
