Flat Food Grade Hose
OrionCalls
OrionCalls Forum Participant Posts: 116 Participant
edited May 2017 in Parts & Accessories #1
I need to buy more hose pipe in order that I can connect my aquaroll to the water supply on fully serviced pitches. Whenever I have been on such a pitch I am inevitably to far away to connect the hose I currently have.
I'm thinking of getting 15 metres of flat food grade hose and was intrigued to find that you can get one made by a the name of Brunner that you apparently do it have to fully unwind it to use!!!
Does anyone have experience of this type of hose which seems to be ideal for the use I want it for.
Thanks
  • TJ49
    TJ49 Forum Participant Posts: 39 Participant
    edited May 2017 #2
    I use one for the MH but I cut it in half and used 'Hozeloc' connectors to joint it. If I can park close to the tap I only need to unreel half of it.
    I keep several 3/4 threaded tap connectors on-board (I have misplaced one or two !) which fit most taps in the UK and EU.
    My only problem was that when I connected it to the water inlet on the MH the hose tended to drop straight down and kink so no water would flow. A few 'Speedfit' parts etc and it now works well.
    For those who say that 'Hozeloc' are suitable for drinking water - we don't drink the water from the tank - we drink bottled water !
