Autocruise Rhythm Bathroom tap problems
AdrianP
Forum Participant Posts: 10 Participant
We are having a lot of problems with the bathroom tap on our 2016 Autocruise Rhythm. The tap quickly works loose and our dealer has attempted to repair it twice already. Now it has not only worked loose but the hot feed to the tap leaking water. The nut to tighten the tap fixing is very difficult to get at.
Has anyone else had this problem and if so how did you fix it?
regards
Adrian
Hi AdrianP..This has cropped up before on 'Swift' produced "autocruise' vehicles.As said before ,the only way is to access the area under the sink by cutting out a piece of the cupboard below the tap , then tighten the securing nut .Then making good the cut out with a section of suitable material,'i e' plastic or fibre glass.replacement.Hope you sort it !!
.3
