battery charger
cityman
cityman Forum Participant Posts: 15 Participant
Hi All
Can any one tell me where the battery charger is on a 2014 Bailey GT GENOA looked under seats but can not find it any idea's. Would appreciate your help.
Stuart
  • JCB4X4
    edited April 2017 #2
    I don't know this particular van so a bit of a guess here but many are contained in a compartment that is part of the electrical control unit and situated directly behind the MCBs and other 12v fuses and can simply be unplugged and lifted out for service or replacement.  I imagine that you already know where to find this unit but if not it will probably be in one of your front bed boxes with an fairly obvious  front access cover.
    Hope this helps.
  • cityman
    edited April 2017 #3
    Hi JCB4x4
    Thank you for your reply sorry I did not reply strait away as have been away I had an Idea it might be there but was not to sure so did not want to start pulling things out and find nothing there so I will go for it and thanks again for you help.
    Cityman
  • JCB4X4
    edited April 2017 #4
    Hello Cityman,
    Thanks for the acknowledgement, I just hope that it is where I have suggested and not in some other obscure place that no right-minded person, other than a Caravan Designer would consider.
    JCB4x4.
  • commeyras
    edited April 2017 #5
    In my Ranger the battery charger is a white 'box' fitted to the back of the fuse box.  Access by lifting the seat.  Have not needed to do anything with so I leave well alone.
    edited April 2017 #6
    In our 2016 Genoa the Batt charger is behind the MCBs and 12v fuses accessed via the bed locker
  • xtrailman
    edited April 2017 #7
    Its inside the PDU.
    You need to remove the PDU front cover the charger is located inside the top and just slides out.
    PDU is the box with the CB,s and ELCB, fuses etc.
