Knaus Power System
ScreenNameCE08C40BC2
ScreenNameCE08C40BC2 Forum Participant Posts: 1 Participant
I have a 2001 Knaus Blueline TK450 fitted with a MIKO MK120 Power Board. It does not have a leisure battery. I am looking to install a Status Visionplus 335 Aerial system with amplifier which I understand requires a 12v to 24V DC supply.
Can I simply take a feed directly from the power board to achieve this?
Moderator Comment - Moved here from the Ask the Expert section
  • xtrailman
    edited April 2017 #2
    If it provides 12 DC I don't see why not, just fuse down if required to protect the wiring size you use.
    If it gives out AC volts you will need to fit a convertor.
