Glass oven door keeps coming stuck from hinge
mikehawkins24
mikehawkins24 Forum Participant Posts: 3 Participant
edited March 2017 in Caravans #1
hi I have a 2007 bailey pagent a great caravan apart from the lower oven glass door keeps coming unstuck from the hinge on one side I have tried different types of glue but the only last 1 to 2 months before coming loose again
does anybody know of a glue that will hold more permantly thankyou mike
  • SRC59
    SRC59 Forum Participant Posts: 4 Participant
    edited March 2017 #2
    Hi
    I had same problem - use a two pack system (glue and hardener which you mix together). Leading make is 'Areldite' but there are cheaper ones.
    Mine has remained stuck for over two years
  • mikehawkins24
    edited March 2017 #3
    hi thankyou for reply I tried a cheaper one
    so I will try araldite next will let you know if works thanks
  • Bluemalaga
    Bluemalaga Club Member Posts: 939
    250 Likes 500 Comments
    edited March 2017 #4
    Have you tried asking Bailey directly?
    customerservices@baileyofbristol.co.uk
    Main switchboard: 0117 9665967
    You might get the answer you need.
  • Toro
    Toro Forum Participant Posts: 48 Participant
    edited March 2017 #5
    Perhaps you need a heat resistant adhesive. I am wondering if the heat from the oven is affecting the adhesive. Try googling "Heat Resistant Adhesive" or try "OvenDoorGlue"
