Power loss
Ant Kenny
Ant Kenny Forum Participant Posts: 3 Participant
I we have no power to living area ,we recently had fuse blow on battery would this have blown fuse to living area as well
  • Whittakerr
    edited December 2016 #2
    Not a lot of information there for anyone to be able to give constructive advice
  • brightstar2
    edited December 2016 #3
    As said - need more info - make / type of caravan/ motorhome.
    You should have an RCD main switchboard somewhere which should include both rcd fuse units and possibly also a bank of auto type fuses
    Check these in first instance and come back with more detail if to no avail
  • Wildwood
    edited December 2016 #4
    Not sure what you have not working but each item will have its own fuse so check them all. There will also be a master fuse which might also have gone. If it is not the fuses then more information is needed to go further.
