DEAD BATTERY - NO PROBLEM - UNLESS...
Aspired
Forum Participant Posts: 5 Participant
If you have a Peugeot Boxer based motorhome here's a tip. If you're planning to store the van or not use it for a while make sure that the bonnet is released so that you can open it to use your jump leads. The bonnet release is "buried" at the end of the dashboard and can only be accessed whilst the passenger door is open. I have found out that if the battery is dead you cannot open that door. Elddis have confirmed that that is the case and there is no manual override. What to do in an emergency is another matter.
