Damp problem in roof on a Compass Drifter
the roof strip over roof at back of roof leaks ,and i want to get a wider strip of aluminium to cover the joint ,made with 2 rows of holes rather than the one at moment, but i need to know the total width of the timber used in construction first so please
can any one help me to resovled it, i hve tried getting in touch with the manufacturer but to no avail
Why not put a strip over it with no holes in it. I have just fastened the electric ariel plate to the roof of motorhome with Sikaflex. You need to leave a couple of mm gap underneath so it can form a joint. I used some small stick on cupboard stops. You could then hold the strip in place with tape until it is dry. Sikaflex forms a rubbery seal and certainly keeps the water out.
0 -
oh right thanks for that idea , its sure needs some flexibility thogh as body does flex at times
0 -
From personal experiance ................ after you have cured the leaks, or before if you like Buy a dehumidifier and a moisture meter. I recommend a Meaco 10L dehumidifier. turn it on and leave it on untill the moisture content of the structure has come
down, you may need to seal of places like fridge vents and stop the outside moisture getting in. Good luck.0
