Electric window problem
Michael Ward 1
Michael Ward 1 Forum Participant Posts: 1 Participant
edited November 2016 in Motorhomes #1
 Drivers Electric window opens ok but closes very slowly
Almosts stops 75% of the way up
Motor Home type.
Hymer B Class B508CL
Fiat Ducato 2008
I suspect this subject has been raised before but would be grateful for some advice
    edited November 2016 #2
  • peegeenine
    edited November 2016 #3
    The simplest thing to try first would be to spray the window channels with silicone and run the window up and down a few times, repeating the spray as required. Try to spray the silicone down the channels into the door too as this may be where the tightness
    is.
  • MeatHome
    MeatHome Club Member Posts: 54
    edited November 2016 #4
    On a mercedes saloon car I found that :-
    Before applying silicone spray slide a piece of thin card along the gap between the window and seal.
    An accumulation of fine grit was hampering the mechanism and triggering the safety mechanism intended to prevent the trapping of fingers
    edited November 2016 #5
    After the easy fix above has been tried ......
    I've no idea what kind of mechanism you have inside your door to lift/lower your window, but the first thing would be to remove the inner door card, then carefully remove the plastic water proof membrame. Some cars use a series of gears, levers and a geared
    quadrant, while others use a cable (like your bike's brake cable) over a series of pulleys. Make sure any moving bits are lubricated
