No power to Control Panel on Bailey Valencia Mk 1
Merve
Hello, I arrived back from the East Coast on Sunday having had 4 days away and everything working fine. Is tied the caravan and found that the alarm wouldn't set but as I was going to work in a couple of hours I left it so I could return later. I have returned
to the problem and find now that not only can I not set the alarm but the main panel won't light up as it always has done. That's probably why I can't set the alarm as its on the 12v line I think? I have checked the RCDs and all the fuses- and I mean ALL the
fuses so I left nothing to chance. I have also checked the rear of the main control panel in case there were any in line fuses- couldn't see any. My question is this- what could it be and have I missed any fuses that might be in another location? I can't think
that it's anything serious as the van was working perfectly up to leaving. I am a non EHU caravanner- not that that should make any difference. The other thing that happened was that I was contacted by the alarm company shortly after arriving at storage and
unhooking and was told that my van showed a 'power down' although the regulator from the SP on the roof says that the batteries are at 13.9v! Any ideas?
  • DSB
    DSB Club Member, Member Moderator Posts: 6,369
    edited September 2016 #2
    Sorry to hear about the electrical problems Merve.  Sounds a bit of a mystery to me.  Sounds like it might mean a visit to a caravan service department.  Frown
  • unicorn212
    unicorn212 Forum Participant Posts: 6 Participant
    edited September 2016 #3
    I use to have a Valencia mk .1 with the alde heating system on top of the boiler is a couple of fuses can't remember which one it was changed it & control panel worked again . Hope it works
