Water/electrical issues Bailey 765 motorhome
sharroj
sharroj Forum Participant Posts: 1 Participant
edited June 2016 in Motorhomes #1
can anyone help with this set of issues?
altough we have hook up working fine there are several things not working. these are:
toilet flush not working (it's full of water but won't pump)
whale water pump not working (we have attached the submersible pump which is dropped into an aquaroll barrel which is full of water.
the water in the van is not flowing either.  it did to start with but since the tank wasn't filling the water went down to about 10% and even though I've topped it up to over 30% none comes out of the taps.
Thanks
John
    edited June 2016 #2
    You have a 12 volt supply missing .... I'd be looking for a blown fuse
    edited June 2016 #3
    John, all the things you have listed operate from the 12volt supply and should work even without EHU as they are powered from your battery. The 12v supply is clearly missing. I would check that the control panel switches and settings are set correctly. Failing that, there is a fault on your 12v system and fuses are a good place to start, as MM said. Check your handbook.
    DavidKlyne Club Member Posts: 14,798
    edited June 2016 #4
    John
    I have a 740 and all that you describe suggests the Master Switch is in the off position. Are the 12v internal lights working?
    edited June 2016 #5
    So, John, have you sorted it yet?
