FIat Ducato Main Battery Drain
Akadingbat
Akadingbat Forum Participant Posts: 1 Participant
edited November 2014 in Motorhomes #1
Hi Everyone, I hope someone can help me. I have recently bought a 2007 Ace Airstream 630 EK and the dealer fitted a new main battery in it before I took over the van. I had no problems the first couple of weeks but when I tried to start up today after it
sitting on the drive for 10 days the main battery was flat. I plugged in the 230v and put the selector to charge the cab battery and it started, once but not a second go so continuing the charging. However on the electric control panel it is showing a constant
12 Amp drain/discharge from the battery. I have checked to make sure that every thing I can switch off is off, other than the alarm system. Any ideas? I am planning to hit the road in a few days time with it but not sure if it is safe to do so. Thanks.
