Waste water tank additive
hitchglitch
edited May 2016 in Motorhomes #1
Our dealer recommended a Thetford product to add to the waste tank which seems quite effective; at least, it has a nice smell! It s going to be costly and inconvenient to use this every time so I wondered what people do? maybe it's just an end-of-trip treatment?
  • briantimber
    briantimber Forum Participant Posts: 1,653 Participant
    edited May 2016 #2
    Just before leaving site we fill the sink with hot water and dissolve a bio pod in it, then drain into waste tank and empty when home or on next site. Never had any bad smells using this method...Cool
    Tinwheeler Forum Participant Trusted Posts: 24,312
    edited May 2016 #3
    We occasionally put something like half a bottle of cheap disinfectant (about 40p per bottle) and a couple of gallons of water in an otherwise empty tank and drive with it in there to give it a good slosh about. Seems to work.
  • thebroons
    thebroons Forum Participant Posts: 165 Participant
    edited May 2016 #4
    What did your dealer recommend the product for exactly and are you having any issues with the waste tank.
  • Bakers2
    Bakers2 Forum Participant Trusted Posts: 8,675
    edited May 2016 #5
    Never put an additive into our waste tank until we got a free Elsan grey water one. Smelt nice and we occasionally use it. Same motorhome 10 years no problems. I'd say regular use will be expensive but your choice. Disinfectant occasionally would be my choice
    if I felt I needed to freshen the waste tank. Pop so e in a d some eaysr and drive a windy road so it gets moved around ?
  • margaretbaker
    margaretbaker Forum Participant Posts: 11 Participant
    edited May 2016 #6
    Like Briantimber we also use washing gel pods every 3 to 4 emptyings . Keeps tank clean and smells fresh,just buy cheap ones from lidl or aldi.
  • margaretbaker
    edited May 2016 #7
    We also use gel pods in toilet waste tank instead of bloo. It cleans ,breaks down waste and smells better than bloo
    edited May 2016 #8
  • Aspenshaw
    edited May 2016 #9
    We clean the waste water tank every 6m maxium with a Thetford product. Follow the instructions and it works. Being careful what you wash down the sink makes a big difference.
    We use Dometic tabs in the toilet waste but find them too effective. Thetford green liquid allows us to put in a small amount for just a day or two out. We mix the pink aqua rinse with water and use that as a spray in the toilet bowl to keep a fresh smell.
    It all depend on how much you use the facilities. You find a way that suits you in time. For us, the cost is incidental in the great scheme of things so we focus on what what works for us and stick with it.
  • royandsharont
    edited May 2016 #10
    A crushed dish washer tablet flushed into the waste tank with a good bit of clean water between sites is a really effective way of cleaning it. The sloshing around gets the full tank clean and bannishes any smells. I had also heard of the cheap cola method
    but not tried it. Regards, Roy
  • pauline058
    pauline058 Forum Participant Posts: 85 Participant
    edited May 2016 #11
    Bit of concentrated Zoflora into waste barrel
    DavidKlyne Club Member Posts: 14,779
    edited May 2016 #12
    I use the Thetford tank cleaner now and again. Having said that I don't recall any nasty smells from our waste tank as it always smells of shower gel!!!
  • huskydog
    edited May 2016 #13
    I take it to put the additive in the waste tank ,you pour it down the sink ??
    edited May 2016 #14
  • huskydog
    edited May 2016 #15
    not necessarily, HD...
    on our Boleros the answer would have been yes....although there was access from outside via a large underneath drain 'cap'.....sometimes i used to stick a hose up inside to wash it out.....
    the Carthago has large opening 'caps' for both waste and fresh tanks, so dropping in a tab or adding fluid to the waste tank is pretty easy.
    just depends on how easy the manufacturer wants (or doesnt want) to make access.
    have a look, you may find a 'flap/hatch' in the floor above your tank....
    Thanks , that is what this weekend at our local site is about , to get familiar with everything and how it all works , just been to get some diesel ,oh ,a few rattles to sort out Surprised,but
    all part of the learning curveLaughing
    edited May 2016 #16
    The advantage of pouring it down the sink and shower drains is that it sanitises the pipes which are as likely to smell as the main tank depending on what you put down them in the first place, especially washing up water.
    edited May 2016 #17
  • Bakers2
    edited May 2016 #18
    Husky enjoy learning your motorhome. Anything we use, see earlier post - its rare, goes down the plugholes.
  • thebroons
    edited May 2016 #19
    We used the cheap cola in our last motorhome when the waste water level gauge decided to stick at full (Annoying alarm) even when empty.
    A few bottles of cola mixed with water and a drive to allow sloshing and this always fixed the problem.
