Electrical problem with Abbey Piper 1995
Options
hi , just testing the plumbing after the winter and the pump will not kick in , I have wired it separately to a 12v battery and the pump works so I'm wondering if it is the pressure switch that is faulty or a fuse has blown (I have found one fuse damaged
4amps ? ) and swapped it over to no avail , also the rocker switch for the pump up next to the voltmeter will not switch on although I'm sure I only need that for the shower , Any help would be appreciated , I'm thinking the obvious solution would be to first
change the rocker switch
