Water Leak Cold Water Tap Supply Pipe
TINA LEWIS
I have a leak (spurting from small hole) in the chrome flexi pipe leading to the kitchen mixer tap (cold water). Can just the pipe be replaced? Also, can I safely run the pump to supply hot water only or will it pressure up the cold water pipe? To that
end, can anyone local to Rugby/Banbury recommend a mobile plumber as it is beyond me.
