On board water tank and pump valves
steveygee
steveygee Forum Participant Posts: 2 Participant
edited February 2014 in Caravans #1
Hi I have just updated my caravan to a swift conqueror 645 lux I have a onboard water tank but I'm not sure where I should have the valves set to I have a pull down drawer under the set of drawers Ideserve the pump can see drain valve but also have 3 more
valves to set for fill tank / onboard tank / or external only but how to set them I no idea I do get water it the taps but like to no which way the vales to be set for different ways  I did ask in a caravan sales but they just wanted to sell not give advise
if I use the external water without the tank do I still get hot water my switch for the pump is above the door also saying water tank full but I opened the drain valve  anyone out there could help thanks
