Lunar delta inboard water tank.
I have recently aquired a Lunar delta RS 2010 model. Something is puzzling me and I cannot get a proper answer even from lunar (another story). In the handbook it states that the inboard water tank is filled from outside,fair enough, It then states that water is drawn from the inboard tank by a pump. Firstly i ask is this another inboard pump to draw water from the tank and the submersible pump in the aqua roll is used purely to fill the tank ? If this is the case then why do the taps not work at all when the submersible pump is removed and the tank is supposedly full of water. Complicated though this sounds help needed. Secondly where oh where is the drain tap for the inboard water tank. I have located the drain tap for the hot water system at least i think so this tap appears to be the same sort as the one on my previous vans Truma water heater. hope someone can help cos what I got when I managed to ring Lunar was firstly "How did you get our number" and secondly we dont actually deal with customers direct. Happy memories of my Bailey days then.
