No 12 volt power in caravan.
Finches
Finches Forum Participant Posts: 1 Participant
We have an Abbey Vogue 2 - 460 2009.
Whilst on holiday, the 12 v system wouldn't work unless hooked to the mains. We put this down to a duff battery and purchased a new one.
However, the 12 v system still won't work. We have checked the in line fuse with a multi meter and that's fine.
Any help or advice would be gratefully received as we are supposed to be going away this week but without the motor mover working it will make life hard!
  • ABM
    edited September 2016 #2
    1}  connect  the  m-meter  across  the  battery  terminals
    2}  check the  voltage  of the  battery
    3}  watching  the  still  connected  meter  have  the  mains  connected
    4}  the  battery  voltage  should  rise  sufficient  to  indicate  if  its  receiving  a  charge  &  thus  is  in  circuit
    5}  if  not  you  have  a  disconnection  between  the  battery  and  the  12  volt  power  cct
    6}  DISCONNECT  THE  MAINS  &  THE  BATTERY !!
    6}  now  carefully  check  all  switches  &  wiring  connections
    7}  Pray  a  lot  whilst  doing  these  checks  'cos  its  Sunday  &  also  your  time  is  much  cheaper  than  an  electricians  Wink
  • MeatHome
    MeatHome Club Member Posts: 54
    edited September 2016 #3
    Are you saying that nothing on 12volts is working?
    A motor mover is normally wired directly to the unit with its own fuse and does not pass though the caravan 12 volt system.
    You say you have a multimeter to check the fuse  -  have you checked to voltage leaving the battery?
    If you have only checked the fuse it may be a duff battery or a bad connection on the battery terminals.
  • MeatHome
    edited September 2016 #4
    Write your comments here...Should read :-
    "Are you saying that nothing on 12volts is working when not connected to the mains?"
  • Rayrowe35
    Rayrowe35 Forum Participant Posts: 112 Participant
    edited September 2016 #5
    When you are towing a relay connects the caravan battery to the car 12 volt system, the caravan circuits are inactivated. If this relay fails to return to the non towing position, the symptoms you describe will be present.
