Pegasus GT65 Bologna - low water flow
speedbird22
speedbird22 Forum Participant Posts: 14 Participant
Just in case others are as stupid as me,I enclose the following info.
I have had low flow on all my taps and shower since i bought the van.I Bought a high flow pump..no better.
I decided in the end to do the obvious..check the filters on the taps. This was after I realised they had filters.
All blocked..now cleaned and the difference is magical.I have one question to Bailey..why do I need 5 metal filters and 2 plastic filters in each tap..?No wonder they get blocked in 5 minutes...
I have also suffered from the bailey mastic blocked awning rail...why do they do this..????? and keep doing it.
and dont criticise my dog...
  • MickR
    MickR Forum Participant Posts: 5 Participant
    edited May 2016 #2
    Interesting, the washbasin tap on our Pegasus Verona has started to flow very slowly and I now wonder if this is the cause. The flow from both the kitchen tap and the shower head  is normal. It would be helpful to know the precise location of the  filters
    that you refer to and how to remove them for cleaning.
  • speedbird22
    edited May 2016 #3
    the filters are in the end of the tap spout.Get an adjustable spanner on the flats and undo the end of the tap.Filters are in there.Assuming your taps are like mine.
Welcome!
