Water pump issues...Sterling Amber Elite 2012
kdee69
kdee69 Forum Participant Posts: 226 Participant
edited February 2016 in Caravans #1
We've had our caravan for about 9 months and just returned from a night away in it.
This time we noticed a few issues with the water...
I've listed them as they may or may not be related but any advice would be great (we are new to caravanning)
1. The pump has definitely gone noisier. It was really loud this time
2. Sometimes, the water indicator would show red and then I'd press fill water again, for a second, turn it off and when I pressed view levels it would show the correct levle (e.g. full or 3/4 or 1/2 but not empty)
3. Occasionally, when I turned on the gas hob (say to heat the kettle), the water pump would start up and the levels would be as above. (red)
And a final unrelated question - advice needed really:
If I want to run a tap, should I have to press the water pump button every time? As currently If I don't, no water will come
Thanks
    KjellNN Club Member Posts: 8,992
    edited February 2016 #2
    Our Elite is a 2008 so has a different water system, but the answer to your final question is NO.
    Are you a member on SwiftTalk?  If not, I suggest you join and post the problem there, you should get plenty of help.
  • rogher
    edited February 2016 #3
    If you were not on EHU, I’d check the state of the battery. Otherwise, I’d try adjusting the pressure setting.
