Water pump in Motorhome
RobNSha
RobNSha Forum Participant Posts: 3 Participant
edited April 2013 in Motorhomes #1
I have a fiat Bessecar motorhome E345(2008), the water pump (Shurflow SUK 0227diaphragm pump is working fine but it is making a noise that sounds a bit like a very fast tapping sound, when the taps are turned on.
Next to the pump is a small container, like a filter when i turn it or move it the noise reduces, however once the taps have been used a few more times the noise increases.
I wanted to know if there is a maybe either a pressure problem or if the van needs to be drained fully and refilled.
We are currently in Spain, new to motorhoming so would really appreciate some advice.
regards
Rob
