Alko atc won't power up.....no whirring noise
jge4596
jge4596 Forum Participant Posts: 2 Participant
edited September 2015 in Caravans #1
hi, I have a 2011 bailey Pegasus.when I connect the 13 pin car connector I don't get the usual elf check noise nor the led light.the problem is not with the car as ve tested my car on other vans and other cars on my van....ive traced cable back to consumer
unit and cant see any inline fuse.all fuses in cu are ok.IM wondering if cable could be damaged or the atc box is basically  dead...ideas?
