S2 Unicorn Water Tank
Hi all, took delivery last month of our new S2 Cartagena, like most S2 owners disappointed about the absence of an on board tank after having them on the last 3 vans (Senators) sorted the problem with a 40ltr micro processor controlled water wizard,
no holes to be drilled, minimum adaption of the water pipes, and comes complete with all the relevant electrical connections, (plug n play) took less than an hour to install and we are highly delighted with our new tank. It allows you to select between out
side water tank, or on board, also has a water gauge to show how much is in the tank, and a low water warning, and also a warning if your leisure battery is getting low. I can highly recommend this bit of kit to any S2 owner who is missing there on board water
facility.
Allan.
