Flowjet water system Coachman Vision
petrod
petrod Forum Participant Posts: 8 Participant
edited June 2015 in Caravans #1
Just taken delivery of a Coachman Vision c/van which is fitted with a Flowjet water supply system which seems o work fine but unlike my previous vans the red light incorporated in the on/off switch remains on even when the onboard pump has switched itself
off after pressurising the system .Can't find any information on this in the handbooks etc but it seems that the pump is capable of operating dry without damage & the only way to tell if the external aquaroll is empty is when the tap or shower ceases to flow.
Hope my assumptions are correct but any other input will be wecome
