TV issues when using 12 volt
leetodd
leetodd Forum Participant Posts: 12 Participant
edited May 2014 in Caravans #1
Hi All
We have a new caravan and not been out in it yet.  We got a 12volt travel led tv but im having issues with it and am hoping someone may have some idea whats going it.
At home on mains (using included transformer) it works fine.  Put it in the van and plugged it into the 12vold socket and the red standby light somes on. Press on and it goes green as just as the backlight comes on it goes of and back to standby.  I though
maybe the battery is low so trying it in the car soctet and it powered on no problem.
Charged the battery and tried again and same issue.  I have messured the car and van battery and the car is about 12.4 and works.  the van was prob about the same before charging and after a charge 12.95 - 13.
I really have run out of ideas with this as it makes no sense.  I even had the voltmeter on the battery when turning the tv on and no drop.  tested the socket on the wall and that matches the battery.
Anyone any ideas
Thanks
