Where is my waste water tank located.
JKH62
JKH62 Forum Participant Posts: 1 Participant
edited December 2016 in Motorhomes #1
Hi, I have just bought a 2001 Elddis Compass Avantgarde 200. Can anyone tell me if this model has a waste water tank onboard and if so where is it located.
Many Thanks
J
  • royandsharont
    edited December 2016 #2
    If this is a motorhome, I see you are a caravanner, then I am sure it will have a waste tank. Just follow the waste pipes from the sink & bathroom and they will lead you to it, possibly visible under the chassis? Mine is a UK van so does not have a
    double floor so my tank is slung under the chassis, a white fresh water tank amidships and a black waste tank slung under the chassis to the rear. I have a pipe off the tank to a tap to empty it. You should be able to find it easily I would have thought if
    you look for any of the above. Regards, Roy
    edited December 2016 #3
  • PaulandKate
    PaulandKate Forum Participant Posts: 64 Participant
    edited December 2016 #4
    Hi we had a 2005 avant-garde 200. The grey waste was under the rear of the mh with the drain tap located just behind the rear passenger side wheel
