Truma water system break
Dave
Dave Club Member Posts: 141
edited February 2015 in Caravans #1
On our first trip away with the caravan, I hooked up the water to discover that the inlet had broken from frost. We have a Coachman VIP with a truma inlet that has an e ter all shower outlet. The outlet links via short hard plastic pipe from the inlet. When
you drain the system down water is left in the pipe unless you remove the cover where the shower plugs in. Forget (as I did) and the result is a break. Managed to fix the water system with five inches of half inch hose and two circlip.
Anybody else had this problem?
Dave
