Unexplained battery drain
JayEss
JayEss Forum Participant Posts: 1,663 Participant
edited August 2014 in Caravans #1
I'm baffled by this.
I accidentally left the 12V master switch on after the last time we were out in the van and to add insult to injury I left the fridge switched to 240v with the door open.  I only noticed when it stopped being sunny and I noticed my battery had gone down.
Now before you say it's the fridge light - there isn't one and looking at the wiring there doesn't seem to be a circuit to the fridge.
When the battery was fully charged again I switched the fridge off and left the door open with the master switch on to test overnight and again the battery had lost charge.
I've tested all the 12v fuses on the control board with a Maplin current tester and all are showing 0.  I guess this is pointing to the mover which is connected directly to the battery but it is switched off and the key is out.
Anywhere else you think I could look?
