Dometic Rml 9330 Fridge door issues
Ianb2108
Ianb2108 Forum Participant Posts: 6 Participant
I have a 2015 Bailey Unicorn which I continue to have issues with my Dometic Rml 9330 Fridge door.
It all started when having issues opening the door and one day it got jammed. The Catch has since been replaced.
The issue I have is that the door edge is rubbing on the top corner of the fridge frame and has taken off the paint and doesn't shut correctly. Has anyone else had this issue as I am trying to get a new complete fridge under warrenty not just a door which
has already been replaced
  • veletron
    veletron Forum Participant Posts: 1 Participant
    edited September 2017 #2
    Fridge catch replacement instructions on my blog: http://www.veletron.com/?p=311
  • Bogart
    Bogart Forum Participant Posts: 34 Participant
    edited October 2017 #3
    You might have an early production model like I have. Do you mean the L/H side of the fridge door catches the wooden frame it sits in? If so mine is same but just put some insulation tape over the fridge door edge. Later versions had a modified frame.
  • chrissies
    chrissies Club Member Posts: 50
    edited October 2017 #4
    We had similar problem our door was catching on the trim of the housing unit when you opened door it would catch on trim and jam dealer moved trim back so it was flush with the wall of the housing unit and no more problems
